No Power (resolved) |
Page <123 |
Topic: No Power (resolved)Posted: 21 Jul 2022 at 3:00pm |
Glad to know you found the problem. Please don't hesitate to reach out at the first sign of trouble. It helps others when you present a problem you encounter and solve, even if it turns out to be a simple one. We all learn from the experiences of others.
Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3432 |
Posted: 21 Jul 2022 at 3:27pm |
Congratulations on fixing the problem. On your 6v batteries for maximum longevity don't draw down below 6.1v per battery or if both are hooked together 12.2v. By following this I have been able to use an 11+ year old battery many, many times and it still works well as we normally camp where there is no electricity as in national parks, state forest campgrounds or just out in the wild. Replaced one of our nearly 11 year old batteries last August with a 12v Trojan T-1275. 166 aH so it will last significantly longer than our other group size 24 battery when boondocking. We don't utilize solar or generator so after 10 days or so (depending on how much the furnace is used) we have to drive down the road for a while to charge the battery back up.
Posted: 21 Jul 2022 at 4:05pm |
Congratulations. Please don't forget to mark this issue as solved so others will know.
ampete
Joined: 18 Aug 2020 Online Status: Offline Posts: 53 |
Posted: 21 Jul 2022 at 8:56pm |
How do I mark it "solved".....?
Posted: 21 Jul 2022 at 9:39pm |
There should be an option under "Topic Options" (gear icon at top of page) to do so.
ampete
Posted: 22 Jul 2022 at 8:37am |
I must see a different version (iMac). I don't have that option, nor do I have a revise reply option as you suggested earlier. I definitely appreciate your direction though.
Thanks for your support. |
Posted: 22 Jul 2022 at 11:52am |
The "Edit Post" is at the top of your reply that you want to edit under "Post Options." The "Topic Options" which is on the purple bar at the far right under the page numbers. Since it is a web browser, you should see the same things that I do. However, I just looked on one of my topics and do not see the option, so perhaps it was removed or limited to moderators.
Posted: 28 Jul 2022 at 3:11pm |
Done.
Page <123 |
