  New Posts New Posts RSS Feed: Spider crack
Spider crack
Mom Dunn View Drop Down
Post Options Post Options   Quote Mom Dunn Quote  Post ReplyReply Direct Link To This Post Topic: Spider crack
    Posted: 02 Jun 2022 at 4:29pm
I have a spider crack probably from a rock underneath the front window. What is the best way to deal with this? I can’t figure out how to upload a picture of it. Thanks in advance 😉.
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2022 at 5:38pm
Is it still under warranty?  If not there is a product sold at auto parts stores that will stop the crack in its tracks if you get to it before it gets large.
Post Options Post Options   Quote Mom Dunn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2022 at 6:31am
It’s not under warranty, we bought in July2020. But thanks for the tip. Will go check the auto store.
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2022 at 11:03am
To clarify, this is in the gel coat below the window, correct?
Post Options Post Options   Quote Mom Dunn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2022 at 1:41pm
this is a picture of it.
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2022 at 1:44pm
You will need the advice of someone who has worked with fiberglass repairs to fill, sand, and re-paint with gel-coat. Then there is sanding and buffing to get it to blend in.
Post Options Post Options   Quote Mom Dunn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2022 at 1:56pm
Like a boat place? We have lots of those here.
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2022 at 2:48pm
That would likely be one of the best places.
pedwards2932 View Drop Down
Post Options Post Options   Quote pedwards2932 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2022 at 5:31pm
If Forrest River carries the gel coat that matches that would help.  You have to grind the cracks out then fill with gel coat.  It is difficult to spray gel coat because it is very thick.  You also have to add a wax to the mix for it to dry.  Gel coat is designed to be sprayed into a mold then the fiberglass is sprayed over top so the gel dries in an air free environment.  A boat shop could do the repair but again it would help if you got matching gel coat for it.
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2022 at 10:18pm
Correction: A catalyst is mixed with the gel coat. For that, a coating is sprayed over the top of the repair to seal it. Later, the coating is removed and the gel coat is sanded to make it level, then buffed until it matches the existing finish. I used to work for Uniflite (now defunct) that built cabin cruisers. That is how the flaws in the gel coat finish were repaired.
