AC Acting Up! |
Page <1234> |
SC for Huskers
Joined: 22 Feb 2017 Location: Goose Creek, SC Online Status: Offline Posts: 144 |
Topic: AC Acting Up!Posted: 30 Apr 2022 at 8:20am |
No, not on my Rpod AC unit, but I have replaced motor start caps. I've used Digikey transformers, diodes, LEDs, switches etc on electronics repairs and building projects. Im not a electronics specialist but am retired Navy and Ma Bell electronic tech who has forgotten more than I remember, LOL. I have an old Digikey paper catalog I can loan you that will have numbers, which normally dont change on electronic components. Epting Distributors in North Charleston might be able to cross reference your cap. I have found that on some days they are willing to help with your project and other days, well, they may be having a bad day.
Happy Traveling,
Tom 2017 172pod 2011 F150 STX |
richardd
Joined: 09 Feb 2017 Online Status: Offline Posts: 61 |
Posted: 30 Apr 2022 at 6:49am |
Thanks Tom, so are you saying you replaced the capacitors on your AC with Digikey capaciters?
SC for Huskers
Posted: 29 Apr 2022 at 7:06pm |
Richardd, I have purchased several parts from Digikey and have been happy with all of them. The capacitors they normally sell are a close replacement on Capacitance and Voltage, but a better quality. Physical size will differ a little from one maker to the next. If you give us the manufacture's name and number on your cap, maybe we can come up with number for a good replacement. |
Happy Traveling,
richardd
Posted: 29 Apr 2022 at 3:12pm |
Had the start capaciter removed. Waiting to hear from Camping World if they can get it. Also called Digikey. My start capaciter has a manufacture date 2014. No one has told me with certainty if they have one or a suitable replacement. Digikey seems to think they have an upgrade version. But I need afirmation, as it has to be the right one, and I only want to do this once.
richardd
Posted: 29 Apr 2022 at 6:55am |
I still don't know what start capaciter to order, or where it's located. I do know I wish I had a young man to climb up and do the work. The capaciter holds a significant charge which can zap you, even with the breaker off.
richardd
Posted: 28 Apr 2022 at 6:32pm |
After watching another video, I suspect it's the start capaciter. He had the same problem, it would run if he spinned the fan blade like me. He replaced the capaciter and started right up. It is running smooth, blowing cold, no noise or rubbing. I think the capaciter is under 20 bucks, if I can find where it's located? and get the right one.Looks like a quick swap out beside the unit on the roof. It's hard to find a video of my particular Dometic AC. Thanks offgrid!
Posted: 28 Apr 2022 at 5:56pm |
If it's cooling the interior like that then the compressor is working and you can rule that out. There isn't a filter on the roof condenser coil but again if youre cooling well once the fans start spinning them then a dirty condensr coil isn't the problem either.
The fan assembly is the problem if you're having to start it by spinning it by hand. Is it binding up or rubbing on somehing? That would explain the noise. If not then a new fan motor is likely your next step. There are replacement kits including motor fans, and connectors for around $150 available online. I imagine the replacement will take some time and will require you to get on the roof. You can stay on hands and knees up there, and place a piece of plywood where you will be working. Also set your stabilizing Jacks so you're not rocking around up there. OTOH I don't blame you for not wanting to get on the roof and doing this. No shame in going to an RV shop and paying them to do it. If you go that way it's likely you'll save enough on labor by just swapping that it's better to get a new a/c unit. |
richardd
Posted: 28 Apr 2022 at 5:55pm |
Just read the the reason I have to kick start the fan is because it has a bad start capaciter. Anybody know where that's located?
richardd
Posted: 28 Apr 2022 at 5:29pm |
I can start it with the thermostat, and it makes a hum. Then I have to manually reach up and give the fan a spin. That gets it started. It ran cold long enough to bring 82 degrees down to the set 72 then it shuts completely off. I've been watching Youtube videos all afternoon. I'm not technically savy. I know little about ACs. But necessity is a good motivater. I leaned it has 2 coils, evaporator, and condensor.I was able to reach in and vacuum the evaporator coil, but it looks like I will have to mount the roof to examine the rear condenser coil. Don't have the ladder or energy yet for that. I don't know if the roof will hold me standing up on it. If I do go up there, I will take some coil cleaner, phillips screwdriver and towels. Anybody know if there is a thin filter besides the 2 little slide out ones inside? Somebody said check for loose wires on top of compresser. Somebody else said it could be a refrigerant leak, and if so I should buy a new AC. But it was just blowing cold air, so maybe it's not that. A professional AC tech said check for dirty condenser coil FIRST, And "AC units are the most neglected thing you own" ?
Posted: 28 Apr 2022 at 5:57am |
If it's just the fan/can motor then it is probably worth just replacing that, but does the compressor start up and the evaporator (inside coil) get cold? I mean really get cold, not just blow some cool air.
You can also usually tell when the compressor starts because there will be a short voltage drop from the high conpressor starting current. If you have an ac light plugged in it will dim (brownout) momentarily. Also, if it's making noise and running rough then it might only be binding on something and be a simple fix. Take a close look to see what causing the noise. The motor turns two fans on a single shaft, one outside for the condenser coil and one inside for the evaporator coil. |
Page <1234> |
