  New Posts New Posts RSS Feed: Ordering parts
Ordering parts
richardd View Drop Down
Post Options Post Options   Quote richardd Quote  Post ReplyReply Direct Link To This Post Topic: Ordering parts
    Posted: 19 Apr 2022 at 7:11pm
Anybody know the nearest R-pod dealer to Charleston SC, for ordering parts?
campman View Drop Down
Post Options Post Options   Quote campman Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2022 at 8:11pm
Hello richardd. Just saw your question and found this site. A dealer locator should do the trick for you.
https://forestriverinc.com/rvs/dealer-locator/r-pod
Good luck in your parts ordering/finding!
Andy
Andy and Laurie
'21 RP192
Red-Green
SC for Huskers View Drop Down
Post Options Post Options   Quote SC for Huskers Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2022 at 8:15pm
Got my Rpod from John's in Columbia and the Forest River website says there is a dealer in Conway.  I would think most items can be purchased or ordered from any RV dealer.
Happy Traveling,
Tom
2017 172pod
2011 F150 STX
Post Options Post Options   Quote richardd Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2022 at 3:58pm
I just spoke with John's parts man. He said the light I'm looking for is obsolete. The problem I'm having is the light in my Dometic fridge, has developed some corrosion from moisture on the connections. I can clean it off and it works for awhile, but eventually it starts beeping. I would like to find that light assembly, or a suitable replacement. I'm currently using an attached motion sensor light, which works, but I have to keep charging it. You would think that if the light is obsolete they would offer a replacement but don't know if they do.
Post Options Post Options   Quote lostagain Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2022 at 6:28pm
You might want to contact the Dometic parts people.  They sell independently of Forest River dealers.
Also, if you can get it cleaned up enough to get it working again, consider slopping dielectric grease all over the parts that get corroded due to the moisture.  It is a silicone based grease that keeps the moisture off the corrodible parts.  Here is one of many listed in Amazon:  https://www.amazon.com/Permatex-22058-Dielectric-Tune-Up-Grease/dp/B000AL8VD2/ref=sr_1_7?crid=NNBTX8TT3CQV&keywords=dielectric+grease+for+electrical+connectors&qid=1650497211&sprefix=dielectr%2Caps%2C79&sr=8-7
Post Options Post Options   Quote richardd Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2022 at 7:06pm
Thanks Fred, believe it or not, I did try the silicone grease but didn't seem to work. The little connectors are covered with a gold looking substance (maybe brass) except for a couple which I scraped off with a knife. It's working now, so I'll wait and see if it beeps again. In the mean time I'll Google Dometic parts. Thanks alot.
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2022 at 8:34pm
Also, put a little drip loop in the wire leading to the light from the back of the refrigerator. It will help keep condensation water from running directly down the wire to the connections.
