  New Posts New Posts RSS Feed: Floor Sagging by John Marucci
_WW_ View Drop Down
Post Options Post Options   Quote _WW_ Quote  Post ReplyReply Direct Link To This Post Topic: Floor Sagging by John Marucci
    Posted: 08 Apr 2022 at 8:59am
Thanks for the answer! :)
2014 RAM 1500
2016 R Pod 179
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2022 at 12:54pm
I can answer that one. Yes. The tubes need to be shortened and new holes for the locking buttons drilled. It was not too difficult.
_WW_ View Drop Down
Post Options Post Options   Quote _WW_ Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2022 at 11:22am
Originally posted by GlueGuy
Originally posted by rawest50
You do realize more than one person can occupy that area at a time?
Your point being?
We have both stood in that area without any floor sag. Ergo, the floor is fairly sturdy to begin with. Adding the hide-a-spare supports the entire area.
Did you have to modify the hide-a-spare because the beams are less than 68" apart?
2014 RAM 1500
2016 R Pod 179
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2022 at 9:26am
Your point being?
rawest50 View Drop Down
Post Options Post Options   Quote rawest50 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2022 at 3:28pm
2017.5 RPod 179
2017 Jeep Unlimited Wrangler
2 Weiner dogs
Great wife puts up with my BS
❤️ Thoroughbred Racing.
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2022 at 11:10am
That looks like massive overkill to me. If the floor is strong enough for most people, and only flexing for people on the upper end of the weight spectrum, I feel that a single cross support would be strong enough without the plate or the gussets.
JMO.
What we did was put in a hide-a-spare in about that position. Adds virtually no weight to the trailer, and supports about the same amount of area.
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2022 at 7:55pm
+1 to the aluminum brace. It really looks good and definitely does not add as much weight as the steel brace I had made.
PilotPodder View Drop Down
Post Options Post Options   Quote PilotPodder Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2022 at 7:36pm
If I were to do it over, I would likely go with the aluminum brace displayed in this video:
SPrins View Drop Down
Post Options Post Options   Quote SPrins Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2022 at 3:37pm
I will be doing a variation of this repair later in the spring. Will document with photos as we move along. I plan on making a grid of sorts using 1.5 inch square tubing and a sheet of 1 inch PVC sheeting. This way I do not have to worry about wrapping the sheeting to prevent water damage.
I will also be bracing the floor that extends over the frame below the slide out. I will be using 3 pieces of 1/4" thick angle iron 3 x 5 inches that is 12 inches long. Will also post pics of that project as well.
I do not believe I have either of these issues occurring with my 2018 - 179; but am taking a very proactive approach to make these items non issues.
2018 R-Pod 179
2020 Ford F-150 3.5L Ecoboost
Post Options Post Options   Quote rawest50 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2021 at 1:39pm
LOL Yep.
2017.5 RPod 179
2 Weiner dogs
