  New Posts New Posts RSS Feed: Interesting battery analysis
Old Man Running View Drop Down
Post Options Post Options   Quote Old Man Running Quote  Post ReplyReply Direct Link To This Post Topic: Interesting battery analysis
    Posted: 10 Dec 2021 at 3:42pm
After contacting the WFCO tech services, I learned that to install a Lithium ion battery I must replace the existing converter, which consists of the 120 volt AC circuit breakers and the 12 volt DC fuses.  He further indicated that the term Control Charger and Converter were really the same thing.  He indicated that I must replace the existing model WF-8735P with model WF-8735-PB-LIS.  The newer model provides the option to switch from Lead-Acid to Lithium to AGM.  The only problem is that the sources of supply are out of stock, so my project may be put on hold until the parts become available.
Also, my RV is pre-wired for solar, but from what I understand you will probably want to connect the solar panel directly to the battery.  I do not intend to make the solar panel(s) a permanent installation, but prefer a mobile arrangement.
I hope that the information I have provided above will be of use to other Forum members.
Thanks for your help, it was most appreciated.
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2021 at 4:28pm
One  correction: You do NOT want to connect the solar panel directly to the battery. It needs to go through a charge controller. The WFCO information is okay as concerning when you are connected to shore power. However, the WFCO converter does not act as a charge controller for a solar panel.
There are two types of charge controllers you can use. PWM and MPPT. See this article for an explanation of what those letters mean:  https://www.generationsolar.com/charge-controllers/solar-charge-controller-types-shunt-pwm-mppt/
Post Options Post Options   Quote offgrid Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2021 at 10:00pm
Re positive vs. negative grounding, that refers to which polarity in the system wiring is connected to the trailer and tow vehicle chassis. That is the negative buss in all but some now antique cars. So yes you need a solar charge controller that can be negative grounded, meaning the negative conductors in the circuit are connected together and never opened, so that the charge controllers battery voltage regulation action is done on the positive side of the circuit.
There is sometimes confusion about positive vs negative grounding effects on the solar modules themselves. Some solar modules operating at high voltages (as in a big residential or commercial grid tie system) need to be positive grounded to protect them from potential induced degradatiin (PID) which occurs via leakage of ions through the glass and plastic encapsulation of the solar cells. While PID can be a big deal with some solar module types operating at high voltages under some conditions it's really a non issue for our little 12V power systems.
Re connecting a solar module directly to a battery +1 on not doing that. First and foremost, there has to be an appropriate fuse or circuit breaker protecting the wiring from the battery to the solar module. That fuse should be placed in the positive conductor (to maintaing negative chassis grounding as discussed above) as close as possible to the battery because the battery is effectively an unlimited source of current if you short it out. The solar module can only produce as much current as it has sunlight shining on it so it doesn't need a fuse (unless you have more than 2 parallel connected solar modules which we don't usually need to get into discussing here).
The other reason not to direct connect is that you can overcharge your battery which especially in the case of Li batteries can cause a really nasty thermal runaway effect resulting in a fire.
Post Options Post Options   Quote Old Man Running Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2021 at 12:19am
Thanks Stephen for keeping me straight on connecting the solar panel directly to the battery.  I misspoke on this issue.   I do know that there needs to be an interfacing charge controller between the solar panel and the battery.  When I said that I intended to connect the solar panel directly to the battery, I meant that I did not intend to use the RV's prewire connection.  Thanks for the link to the solar panel article and thanks to Offgrid for his detail explanation.
BeeDee View Drop Down
Post Options Post Options   Quote BeeDee Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2026 at 5:52pm
when we recently purchased our 2021 Rpod 192 it was pre wired for solar. We had the dealer install a solar panel on the roof and they also installed the solar charger on the wall next to the entrance door. The charger has a menu that allows for a change that you can switch to the type of battery installed including Lithium. We currently have a 12v acid type battery but I am considering a change to lithium, in which case I will just go into the menu setting on the charger and make the battery selection change, easy!
