Boondocking Prep |
Page <1234> |
| Author | ||
marwayne
Topic: Boondocking PrepPosted: 30 Nov 2021 at 8:47pm |
Here is a comparison, I have Honda 2000i eco mode 48 db full throttle 57 db that means your geny is 8 times louder the my Honda
poston
Joined: 28 Mar 2018 Location: Nevada Online Status: Offline Posts: 212 |
Posted: 30 Nov 2021 at 9:28pm |
Loudness doubles at an increase of 10db, so 48->57db is less than double, about 1.86x. |
-- Jim Virginia City, Nevada 2023 R-pod 153 BEAST MODE! 2015 Nissan Xterra |
marwayne
Posted: 30 Nov 2021 at 11:29pm |
Sorry my mistake, I didn't have reading glasses on and read 1.0
Posted: 01 Dec 2021 at 5:53am |
Yeah, OSHA does not require grounding on mobile systems. If you did actually ground it you'd then have to follow the NEC which would require two rods embedded 8 ft rods spaced at least 6 feet apart. Good luck pulling those when you want to break camp.
I'd still suggest you consider getting two 6V golf cart batteries if you can stand the tongue weight. Having the flexibility to go a longer time between generator charge intervals is very helpful and it also allows you to reduce the depth of your battery cycles which I creases battery longevity. As for,Li batteries consider doing that upgrade after you see how things work for you with lead acid batteries first, that way you'll have a better idea what you really need long term. |
DaveB1701
Joined: 24 Jun 2021 Location: Green Bay, WI Online Status: Offline Posts: 36 |
Posted: 01 Dec 2021 at 6:00am |
Re: Tars Tarkas About ready to ditch this site based on "I know better than you" comments like this, as opposed to honest insight and suggestions, which MANY have given...
2021 R-Pod 171
2017 Chevy Colorado Z71 V6 Just me & my pooch Mr. Buster... |
DaveB1701
Posted: 01 Dec 2021 at 6:04am |
Re: offgrid
Thank you...will add your input to my final analysis and implemetation. DB
2021 R-Pod 171
Posted: 01 Dec 2021 at 11:44am |
The purpose of a bonding plug is to connect the receptacle neutral and ground pins together at the generator when it is connected to an electrical system without an earth ground
Many generator manufacturers don't do that internally because there can be only one point of common connection for the system. They don't know whether you are connecting the Genny into an existing grounded system or using it for a mobile application. If there is no connection between neutral and ground the circuit analyser interprets that as an a open ground condition and won't connect. A bonding plug remedies that. It also allows the gfci's in your trailer to function normally. Hope that helps. |
Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2780 |
Posted: 01 Dec 2021 at 3:54pm |
In the RF world, 3db is double (or half depending on which way you're going). 48db -> 57db is almost 10X.
Posted: 01 Dec 2021 at 5:40pm |
You're both right. The sound pressure level increases 10x with a 10 dbA increase. That is perceived as about a 2x increase in noise level. Put another way our perception of sound level is non linear.
I can say that I perceive my Honda 2k, supposedly one of the quieter gensets out there, as really quite lowd and irritating at or near full load. At low load where it's running at low rpm, it seems pretty quiet. |
Joined: 14 Jan 2013 Location: Near Nashville Online Status: Offline Posts: 1456 |
Posted: 01 Dec 2021 at 8:44pm |
I just looked back in the thread and you have asked a few questions, but mostly you just announce what you're doing or going to do. And you come across as kind of a newbie, so I didn't, and still don't know how you plan to keep your generator in place while you're driving down the road. If you're happy with with whatever your plan is, great. And if there's no one within miles I guess it's only your problem how loud the generator is, and if you already have it, that's one thing, but if it's what you're planning on buying, it's more power than you need for everything in your Pod, so it's more weight than you need to fool with. If you're buying a new genny, I'm pretty sure you'd be happier spending money on lower noise than more watts and weight. Also, you didn't seem to know about a bonding plug, which is a bit esoteric Your surge protector may not work with your generator without one. (Arguably, you don't need it with your generator, but it could take a while to figure that out.) TT
FJ Cruiser |
Page <1234> |
