  New Posts New Posts RSS Feed: Microwave
Topic ClosedMicrowave
Sfoget View Drop Down
Direct Link To This Post Topic: Microwave
    Posted: 17 Aug 2021 at 8:59pm
I have a new RPod 202. The microwave is not working.  Any ideas why?
Direct Link To This Post Posted: 17 Aug 2021 at 9:15pm
Could be different reasons. First, do you have some power available? Second, if you do, did you check the brackets to make sure the one for the Microwave isn't tripod? This, and related, did you check your ground fault little to make sure that isn't tripped?
Has it ever worked? If so, what changed?
If l power checks are good, contact your dealer. If is covered under warranty.
Direct Link To This Post Posted: 18 Aug 2021 at 5:58am
I do have power. Will check the brackets and ground. The microwave starts and then stops after about 10 seconds. The clock goes back to 00:00.
Direct Link To This Post Posted: 18 Aug 2021 at 8:41am
Oops. Typing on the phone along with auto-mistake means that I meant breakers, not brackets.
GFI is also what I meant.
