  New Posts New Posts RSS Feed: Air conditioner leaking when on
Topic ClosedAir conditioner leaking when on
marshel View Drop Down
Direct Link To This Post Topic: Air conditioner leaking when on
    Posted: 04 Aug 2021 at 9:24am
You have to remove the filters to access some of them:
Harry & Lizanne View Drop Down
Direct Link To This Post Posted: 04 Aug 2021 at 3:43pm
I remove 6 screws and filters, check everything I could see and no visible water, took the cover from the roof portion and toward the rear found a leave in what appears to be a small opening.  I have ran the ac now at home for two days and had no leaks now that I r3moved the le@ve let see how it does.  Also I lower the front and a little to one side.
Direct Link To This Post Posted: 04 Aug 2021 at 3:49pm
I only had six screws did not have the two closer to the middle c3nter.
Direct Link To This Post Posted: 04 Aug 2021 at 3:51pm
Thanks to all that responded to my needs, I will let everyone knows after my next trip coming soon.
Direct Link To This Post Posted: 04 Aug 2021 at 4:20pm
I think you will be okay now that you removed the leaf blocking the drain. Good job on getting it figured out and thanks for reporting the results.
