  New Posts New Posts RSS Feed: Air conditioner leaking when on
Topic ClosedAir conditioner leaking when on
Harry & Lizanne View Drop Down
Direct Link To This Post Topic: Air conditioner leaking when on
    Posted: 30 Jul 2021 at 9:05am
Good morning, we have a 2019 Rpod 180 and sometimes the air conditioner has a drip inside the unit. We had it checked out while it was under warranty and they couldn’t find any problems. We are camping at this time and it has rained often. We have the same amount of dripping, regardless if it rained or not. We have had to place a small doggie pad to collect the drip. Could it be moisture? Appreciate any help. Ouch
Colt View Drop Down
Direct Link To This Post Posted: 30 Jul 2021 at 10:28am
Condensate is supposed to drain onyo the roof and flow down one corner.  check to see if your drains are plugged of if the catch pan has a leak, bend or other fault.
John
'16 R-Pod 180
Direct Link To This Post Posted: 30 Jul 2021 at 2:44pm
Thank you will do.
RoverPod View Drop Down
Direct Link To This Post Posted: 30 Jul 2021 at 6:57pm
Also, you might need to take the inside cover off and tighten the bolts that compress the gasket. They might have loosened up.
2017 F150 XLT SuperCab
2020 rPod 180
Direct Link To This Post Posted: 31 Jul 2021 at 8:18pm
Thanks will do.
mjlrpod View Drop Down
Direct Link To This Post Posted: 02 Aug 2021 at 10:24am
I'm not sure what model or year you have, but the a/c will drip water whenever it runs. Of course, it should NOT drip inside. Not sure what year it started, but You should have 4 small "gutters" sticking out from the roof. They direct the dripping water to drip at one of the front or rear corners of the flat section of roof. Maybe if you level your camper with the front or back tipped down just a bit, it might help you get the drip to go where you prefer it to go.
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Direct Link To This Post Posted: 03 Aug 2021 at 5:28pm
Thanks. I have it park at home And have no problem.  Tilted a little bit backward hopefully they fridge will work well. I haven’t figure out how to take the inside cover off only see two screws but did not came off.
I have to take the outside cover and see.
Direct Link To This Post Posted: 03 Aug 2021 at 6:19pm
Can one one tell me how to remove the inside cover, I can only see to screws which I removed but could not remove the cover.
Direct Link To This Post Posted: 03 Aug 2021 at 9:02pm
There are at least 8 if I remember correctly. Check behind flaps and look in the circular holes with a flashlight. You will find them eventually.
Direct Link To This Post Posted: 04 Aug 2021 at 8:30am
Thanks
