  New Posts New Posts RSS Feed: CO Alarm going off during travel
Elie View Drop Down
Post Options Post Options   Quote Elie Quote  Post ReplyReply Direct Link To This Post Topic: CO Alarm going off during travel
    Posted: 15 Dec 2021 at 11:31am
LPCO. Got it and thank you so much!
Post Options Post Options   Quote offgrid Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2021 at 8:09am
Intertek is a certification company, like UL is. I dont think they are the manufacturer, you're most likely looking at the certification logo.
Any RV LPCO monitor should work fine.
Elie View Drop Down
Post Options Post Options   Quote Elie Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2021 at 6:43pm
Hi guys,
My unit seems to be an intertek 45-741.
I'm trying to find a replacement alarm unit and with no luck.
Is there another fully compatible modelthat I can get that anybody knows about?
Thank you!
- Elie
RPodFan775 View Drop Down
Post Options Post Options   Quote RPodFan775 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2021 at 12:59pm
So it's been 2 months and about 10 days of camping, and the alarm has not gone off again. The only thing I can figure is that it was triggered when we pulled into gas stations. Whatever it was, it has solved itself, evidently.
I just checked the monitor and the light is solid green. Pushing the Test button yields the alarm, pushing it again turns it off. So it is working fine and not end of life. We will keep tabs on it.
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2021 at 2:56pm
Your LP/CO detector should have a light. It should also have a test button. Push that. If it sounds, then it is working. If not, then take it off and see that the wires are connected. If they are, it is likely bad and will need to be replaced. I replaced ours with a flush mount when it started giving the end-of-life signal.
If yours is used, the prior owner may have cut the wires.
Gualalapod View Drop Down
Post Options Post Options   Quote Gualalapod Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2021 at 11:00am
I was going to ask how to check to see if the CO detector is working.  Now I Know, Lysol test.  But...if anyone else has a better way to check please let me know.  Ours is from 2015 and has no lights on or anything.
Gualalapod owner
john in idaho View Drop Down
Post Options Post Options   Quote john in idaho Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2021 at 6:45pm
Just curious----whyLysol in the trailer?
TheBum View Drop Down
Post Options Post Options   Quote TheBum Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2021 at 11:10am
Not just Lysol. Any product that has petroleum distillates in it can trigger a propane alarm. My wife even had it happen with non-aerosol floor cleaner.
Alan
2022 R-Pod 196 "RaptoRPod"
2022 Ram 1500 Lone Star 4x4
Three cats
Post Options Post Options   Quote Leo B Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2021 at 5:38am
We had that happen when we first bought our 179 it just ended up being bad, easy and quick to replace.
Kup-Pod View Drop Down
Post Options Post Options   Quote Kup-Pod Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2021 at 7:57pm
Let me start by admitting that I'm obviously a slow learner!
For the third time now I have sprayed Lysol in the trailer and realize that Lysol aerosol spray sets off the CO detector.  I've confirmed this three times (all about a year apart by the way, so it's my long term memory that's the problem! :-))
So, lesson learned, don't spray Lysol aerosol spray in the RPod!:-)
2017 RP-178
2021 F150 5.0l
"Lead me on a level path"
