  New Posts New Posts RSS Feed: 12v system not working, R-POD 180
Topic Closed12v system not working, R-POD 180
 Post Reply Post Reply Page  <1 234
campman View Drop Down
Direct Link To This Post Topic: 12v system not working, R-POD 180
    Posted: 20 May 2021 at 10:45am
I am still thinking you may have a good (not) ground situation going on, that would be right at or close to the battery itself. With a bad ground nothing works right.
Watching and pulling for your successful conclusion to this, and still thinking about alternate causes. Keep us updated with your findings.
Andy and Laurie
'21 RP192
Red-Green
Direct Link To This Post Posted: 20 May 2021 at 10:54am
Reread OG's post and suggest going a bit further than just disconnecting the solar charge wires. I suggest disconnecting all wires from your battery. Test the battery, only SECURELY reconnect the wires leading to your power distribution panel. Test your system...you get the idea. Simplify the system you are troubleshooting.
Andy
Andy and Laurie
'21 RP192
Red-Green
flgbanjo View Drop Down
Direct Link To This Post Posted: 20 May 2021 at 12:56pm
SOLVED!  Thank you everyone for your comments, questions, and support!  Turns out it was a flakey shut off switch at the battery I had installed. It tested ok for continuity a couple of days ago so I eliminated it as a potential issue. Turns out that was a bad idea. Tested again today and no continuity. So I bypassed the cut off and went direct to the battery and voila! And yes, I should have done that at the beginning! So, lesson learned, always go to the battery first and then backtrack from there. Packing the trailer up for a long weekend of camping!  This forum rocks and you people are phenomenal!
Direct Link To This Post Posted: 20 May 2021 at 2:00pm
Glad you got it fixed for your trip!
Direct Link To This Post Posted: 20 May 2021 at 2:38pm
Way to go flgbanjo, so glad that you found it and you are good to go for the weekend!
Andy
Andy and Laurie
'21 RP192
Red-Green
JR View Drop Down
Direct Link To This Post Posted: 20 May 2021 at 3:54pm
It really gives you a sense of accomplishment when things go right.  Have fun on your trip because you earned it.
Jay
179/2019
