  New Posts New Posts RSS Feed: Solar for outlets
Topic ClosedSolar for outlets
Beth81 View Drop Down
Direct Link To This Post Topic: Solar for outlets
    Posted: 24 Apr 2021 at 9:10pm
But I was hopeful they would have one solar powered elect outlet by the bed.  Wishful think, I suppose
campman View Drop Down
Direct Link To This Post Posted: 24 Apr 2021 at 8:31pm
"Solar ready" is the same as when you look at a house for sale and the ad states that "a basement bathroom has been roughed in". Or, if you wish..."central vacuum system has been roughed in". Somewhere along the line someone has to pay for the additional hardware required to make the system work.
It is important to remember that even with a small solar system, you will not be able to use heavy electrical equipment like the a/c or the microwave. For that a generator would be required.
Andy and Laurie
'21 RP192
Red-Green
Direct Link To This Post Posted: 24 Apr 2021 at 3:59pm
For sure I’m not going to be vacuuming my camper. It it does seem that they would put all necessary solar in so one could just plug up some external solar panels.
podwerkz View Drop Down
Direct Link To This Post Posted: 24 Apr 2021 at 3:45pm
Originally posted by Beth81
I just assumed that if the lights fed off the battery that the outlets, or at least one outlet, would also feed off the battery.   I thought that being wired for solar would include an installed inverted that would feed an outlet.
Nope. Gotta add your own. Many newer RVs, especially more expensive ones, do come with pre-installed solar panels, solar controllers, a couple of decent sized batteries, and a nice inverter.
But you bought an r-pod and they tend to be kinda basic. I do know that some of the newer, bigger r-pods now come with a central vacuum....what's up with that? Who buys a small camp trailer and decides that they just gotta have a central vacuum system?
Ying Yang
But I digress.
Let us know what you decide.
Direct Link To This Post Posted: 24 Apr 2021 at 2:30pm
A lot depends on what CPAP machine you have. I have a DreamStation. It runs on 12V. I run it in the RPod from a 12V power outlet I installed in our 2016 RP179. I don't need to use the 110V power adapter. I just use a 12V cord ordered off Amazon. I actually have a spare because I did not know that the cord for my prior machine would have worked just fine.
Some machines are 24V. You could get a DC to DC converter and skip the inverter altogether. I would recommend investigating what DC options are available for your machine.
Direct Link To This Post Posted: 24 Apr 2021 at 1:50pm
That is a common misconception...wired for solar usually means it has the wiring installed. The rest of the important bits are still needed to make it work. The rp192 we ordered and are waiting for already comes with a 100 watt solar panel mounted on the roof and a 1000 watt inverter integrated into the trailer electrical system from the factory. This will be to support my cpap machine as well.
Andy and Laurie
'21 RP192
Red-Green
Direct Link To This Post Posted: 24 Apr 2021 at 1:39pm
Thank you so much for the info. I will have to do some more studying. I just assumed that if the lights fed off the battery that the outlets, or at least one outlet, would also feed off the battery.   I thought that being wired for solar would include an installed inverted that would feed an outlet.
Direct Link To This Post Posted: 24 Apr 2021 at 1:36pm
Originally posted by podwerkz
You will need either a pure sine inverter (12v to 120v) to run the c-pap when off-shore power (no hook-ups) or you will need to buy a 12v powered c-pap, called a travel c-pap.
A portable travel c-pap will probably need recharging after each overnight use...however some units have multiple battery and charging options.
Here is one place to begin your search:
If you decide to keep using your existing c-pap and install an inverter in the r-pod, do not cheap out on a modified sine wave inverter for $50. You will need a good high quality inverter, it will be powering medical equipment after all. Depending on your particular c-pap, normally they can be powered by a good 300-500 watt pure sine wave (PSW) inverter. Expect to pay around $150-$300 for a decent one.
If you post the label ratings (volts, plus either watts or amps) we should be able to narrow it down.
Direct Link To This Post Posted: 24 Apr 2021 at 1:34pm
I should add, that if you are thinking of integrating solar panels and pure sine wave inverter into your rpod, that to do it properly a charge controller suited to the type of batteries you have should also be installed. And I would imagine 2 12 volt deep cycle batteries or 2 6 volt golf cart batteries would be needed.
Andy and Laurie
'21 RP192
Red-Green
Direct Link To This Post Posted: 24 Apr 2021 at 1:24pm
I think you are going in the right direction in order to support your cpap machine when you are off the grid, and as always the devil is in the details. I would think your pod is prewired for solar, so you can utilze that for plugging your solar panels in. You would need to install (or have installed) a pure sine wave inverter as podwerkz stated, that is tied into your pod electrical system. Your outlets would then be provided with 120 volt electricity (limited by the size of your inverter and battery(s) you have installed in your pod.
For travel and going to our off the grid camp, I have a special lithium battery pack that lasts me 2 nights at a setting of 4-8 air pressure and no water or hose heater turned on (it is a resmed 24 volt cpap) to moisten the air...they use too much electricity.
Andy and Laurie
'21 RP192
Red-Green
