  New Posts New Posts RSS Feed: New Here - With a Few Questions
Topic ClosedNew Here - With a Few Questions
nile View Drop Down
Direct Link To This Post Topic: New Here - With a Few Questions
    Posted: 22 Apr 2021 at 10:14am
Hi all,
On Saturday we are picking up our 2017 R-POD 178, and I have a few questions.
(1) It will be parked on land 2 hours from us (no electric) for weeks at a time when we're not using it.  We are concerned about the batteries draining when not in use.  If we disconnect them, are we okay?  We know it's wired for solar, but don't know how powerful a cell we need (100W/200W/400W) to use it untethered for a weekend with A/C and fridge.  Can anyone recommend a solar cell kit from Amazon?  Do we need the controller, or does the R-POD have one built-in?
(2) The previous owners got it serviced by a camper dealer every year but hadn't done it this year.  How urgent/important is it to take it to a dealer before we take it on a trip?
(3) What do wish you'd known when you bought yours?  This is our first camper.
Thanks, so glad this forum exists!
brian
pedwards2932 View Drop Down
Direct Link To This Post Posted: 22 Apr 2021 at 11:33am
I added a battery switch so you can turn off any draw on my r-189.  Seems to work fine as battery holds voltage.  You can just disconnect but that gets old after a while.
Direct Link To This Post Posted: 22 Apr 2021 at 11:45am
Congratulations Brian on your 178.  Be prepared to make a lot of great memories as you travel across this blessed land.
1)  Do disconnect your batteries when not using for a few days or more as there are parasitic draws that will drain your batteries over time.  This is a good time to purchase a multimeter/voltmeter.  If you have 12v batteries than you want to read at least 12.72v from each or from a pair of 6v when they at rest and not plugged in to either solar or 120 shore power.  Your 178 probably doesn't have solar built in unless the previous owner added it.  We don't have solar on our 177 so while i cannot give advice there are many on this forum who will give you expert advice on this.  Hold on, this is your 2/7 owners manual.  Currently I have a pair of 12v Interstate group size 24 deep cycle batteries that will power me for 6 days when temps are in the 40's (furnace runs a lot during this time) as well as running both fridge and HW on propane.  Do not run batteries below 60% S.O.C. or 12.2v before recharging, the onboard converter on the 178 will do that as you travel down the road with the 7 pin Bargman plug hooked up.
2) Being it is your first camper I would recommend you take it to a dealer to have it looked at OR have the previous owner you are purchasing it from go over it with you, that would be ideal and at the same time record it on your phone as you will receive information overload and will be able to reference all the info at a later time as needed.
3) Check tire pressure if Load Range C then 50psi (cold), if Load Range D then 65 psi.  Look at manuafacturing date on the tires, strongly recommend replacing if older than 5 years.   Depending on tow vehicle you may wish to utilize either a friction bar (anti-sway bar) or wdh for safer handling.  Check to make sure everything works BEFORE leaving: outside as well as interior lights, furnace, HW heater-make sure tank is full of water before testing on both 120 and propane,  have person you are getting 178 from show you how to access the winterization valves (2 or 3) under the queen bed at rear of the camper, stove burners, A/C, water for sinks, showers, toilet, check microwave,  Dometic fridge, check to see it will function on 120 (after on - wait 5 minutes and place your hand on the heat stack on the back side of the fridge- it should feel warm or you should feel some heat coming out of the chimney at the top of the stack, after that turn on propane and go to the lower back of the fridge (remove lower vent outside) and look to see and hear the ignitor as well as see a small blue flame in the combustion chamber area.  Get a good stepladder and look to see on top how well all the dicor sealent and caulk is looking around the ff fan, a/c unit, and 2" vent stack as well as the antenna.  Run you slide in and out a couple times as well to make certain it is fully functional.
Any other questions that come up, please ask.  All of us on this forum were once in your shoes asking the same questions.Thumbs Up  Enjoy your new toy.
Colt View Drop Down
Direct Link To This Post Posted: 22 Apr 2021 at 1:52pm
I have a battery disconnect.
A 25 watt solar panel and a 45 watt Battery Tender charge controller will keep the battery hot even with limited sun hours over the whole year when the battery is disconnected.
John
'16 R-Pod 180
poston View Drop Down
Direct Link To This Post Posted: 22 Apr 2021 at 2:49pm
I don't know if it's what you meant, but you're not going to be able to run your air conditioning on battery without a very expensive upgrade (like as much as your Rpod cost!)
Jim
Virginia City, Nevada
2016 R-pod 180
2015 Nissan Xterra Pro-4X
ribet View Drop Down
Direct Link To This Post Posted: 22 Apr 2021 at 3:00pm
I have a 180 with two batteries and 300 watt on top.  Make sure your batteries are deep cycle rv and not duel purpose batteries.
nile View Drop Down
Direct Link To This Post Posted: 22 Apr 2021 at 3:08pm
I'm looking at systems like this one:  https://www.amazon.com/Renogy-Monocrystalline-Solar-Starter-Wanderer/dp/B00BCRG22A/ref=sr_1_2_sspa
to keep the battery "topped off" when we leave it on our land, and I'm wondering if anyone uses something like this and has recommendations.
brian
Direct Link To This Post Posted: 22 Apr 2021 at 3:10pm
If you want to run off shore power for only a weekend Colt's recommendation for solar is fine, it will have a week at least to recharge before the next use, assuming you can leave the solar module connected and in the sun.
If you want to boondock for more than a couple I'd days then get 2 6V golf cart batteries and a 100 watt or so solar module. If you want to run the a/c and micro you'll need a generator.
If you have solar connected you don't need to disconnect the battery. If you don't then you should disconnect it but know that it will still need recharging every few weeks even if not connected.
The biggest cost item surprise with a used rpod is water damage. That can make a trailer unsalvageable. Everything else is fixable. Inspect carefully, especially around the floor perimeter, in the slide area, and around the windows.
You might want to get a wood moisture meter. They're cheap and handy. Dry wood should be no more than 20% moisture content.
