Page <12 |
Olddawgsrule
Joined: 20 Sep 2017 Location: New Hampshire Online Status: Offline Posts: 1014 |
Topic: Generator QuestionPosted: 13 Apr 2021 at 3:40pm |
Capacitors! Want to build one? There amazing little things that do so much. a capacitor bank at proper amperage would allow hard draw to hit the mains, yet be softened until capacity has reached. We've talked about this before as to what a 'soft-start/Easy-start' is! Basically a capacitor bank. Ever wondered why a MPPT works when a cloud passes by? Ya, very cool little items..
Posted: 13 Apr 2021 at 3:09pm |
What would work is if there were some way to connect a relay that would start with the load disconnected and then power on after it is on and stable. I don't know if such a device exists, but if so, that would be great.
Olddawgsrule
Posted: 13 Apr 2021 at 2:28pm |
You have it right. It's the same as the generator we have at home. No load start. Be sure there's no appliances on and awaiting (again, just like at home) to cause an immediate surge (or worst spark as you plug in). Your assumption and caution is correct! Safe Travels!
Gebaldwin1
Joined: 14 May 2017 Location: CT Online Status: Offline Posts: 24 |
Posted: 13 Apr 2021 at 1:51pm |
When in doubt, refer to your owners manual. All will direct you to remove all electrical loads before starting . Pulling the plug is simple enough. Starting under load can result in damage to generator or equipment on the trailer.
GMan
Lil' Bumpy - RPod 180 |
Hardwear Hank
Joined: 07 Mar 2021 Location: Long Island, NY Online Status: Offline Posts: 31 |
Posted: 11 Apr 2021 at 8:00am |
Some generators will over speed on start up until the engine governor retards the RPM to operating speed. During this short interval you run the risk of a short spike in voltage. This event is in some of the lower cost units, better unit control this start up spike electronically.
dasbryant
Joined: 09 Apr 2021 Location: Aurora Online Status: Offline Posts: 5 |
Posted: 11 Apr 2021 at 5:54am |
Thanks for the responses, guys.
The A/C definitely wouldn't be on, nor any other appliances. The only appliances that would be on would be one or two ceiling lights. My CPAP runs off the inverter, so I'd be sure to switch that off first. Hit the remote for the Generator, let it warm up for a few minutes, then start the coffee pot. Sounds like a plan . . . Thanks again.
Joined: 14 Jan 2013 Location: Near Nashville Online Status: Offline Posts: 1456 |
Posted: 10 Apr 2021 at 10:57pm |
It may not be best practice, but as a practical matter, you don't have to start the generator at zero load. I would not recommend starting it with air conditioner and/or the coffee maker on, but you should be fine starting it with a few lights and the converter on. TT
FJ Cruiser |
Posted: 10 Apr 2021 at 10:33pm |
If you turn off the main 30A breaker, that should do the trick. That does not have a remote, so you will need to go to the power panel to do that manually.
dasbryant
Posted: 10 Apr 2021 at 5:41pm |
We have a 2020 rPod that we'll be taking camping soon. I have a simple but very pertinent question.
When boondocking, I believe that the proper sequence of events is to first unplug the power cord from the generator - then start the generator and let it warm up a bit - then plug the power cord into the generator. I've heard that leaving the power cord plugged into the generator and starting it can put a strain on the electrical system? If this is the case . . then my next question would be whether turning everything off inside the camper first, then starting the generator with the power cord plugged in would be OK? We have a remote-start generator and it would be great to start the generator from 75' away, letting it warm up a bit, then turning on the coffee pot and any other electrical appliances we would need. Thanks
Page <12 |
