  New Posts New Posts RSS Feed: Battery Issue
Topic ClosedBattery Issue
Direct Link To This Post Topic: Battery Issue
    Posted: 17 Mar 2021 at 12:16pm
What did you find out, was one of the cells really low or was a load test given and just shown the battery to have failed the test?
With proper maintenance batteries can last quite a long time.  I have a pair of group size 24 Interstates that were built 12/2010 and 3/2011 and get used a lot - we usually boondock.  Big thing for us is not to draw down below 60% S.O.C. or 12.2v before charging again as well as keeping an eye on electrolyte levels and fill with distilled water when getting low.
Ben Herman View Drop Down
Direct Link To This Post Posted: 17 Mar 2021 at 1:10pm
Battery failed. I'm pretty careful about drawdown, I use a solar 100W panel to keep it charged up (we almost always have sun out here in CO). I think that the weak link may be a cheap Harbor Freight trickle  charger that I kept attached to it over the winter. Will get a better battery conditioner for next winter.
podwerkz View Drop Down
Direct Link To This Post Posted: 17 Mar 2021 at 3:15pm
Yes, 5 year old battery, and questionable charger.....if it was the CenTech brand from HF those things are JUNK. I would recommend you buy either a Samlex or Battery Tender or Marinco or NOCO charger...they are all decent quality.
Anyway, new battery, it should all be working now cuz it sounds like your RV converter unit is fine.
Direct Link To This Post Posted: 17 Mar 2021 at 3:35pm
5 year lifetime is normal for a deep cycle battery, whether it gets cycled or not. Batteries have a shelf life, which is shortened by warm temperatures and effected by battery chemistry. The lead antimony alloy used in deep cycle battery plates shortens their shelf life but gives them more cycling ability.
Batteries also have a cycle life, and the number of available cycles depends on depth of discharge and on plate design and alloy. It’s a race to the finish line depending on whether cycle or shelf life is shorter. You can think of deep cycle batteries as optimized more for cycling than shelf life, so you wouldn’t want to use them if you didn’t do much cycling, like for example in a starting battery.
Bottom line is that 5 year old deep cycle batteries don’t owe you anything, time for a new one.
Direct Link To This Post Posted: 17 Mar 2021 at 3:49pm
yes this makes sense. We have very hot summers here and the place where I park my trailer is in full sun. I'm sure the  ambient temperature is 110+ inside the battery box. I might consider pulling the battery and storing it in my garage after each use - only takes me 5 minutes to do so. I always thought cold was more damaging but I was wrong!
Thanks again for all of the assistance. All now working fine.
Direct Link To This Post Posted: 17 Mar 2021 at 4:13pm
Heat accelerates almost all chemical reactions, including corrosion rates. A rough rule of thumb is that reaction rate doubles for every 10 deg C (18F). So at 110F you are getting something around a 4x reduction in shelf life of a battery relative to what you’d get at 70.
But the temp effect on chemical reactions causes batteries to have more internal resistance when they’re cold, because batteries undergo a chemical reaction when they charge and discharge. So they produce less current at a given voltage and need higher voltages to charge properly when they’re cold. That’s why people think cold is bad for batteries.
Direct Link To This Post Posted: 17 Mar 2021 at 4:23pm
So there is one advantage to living in northern Michigan where the sun goes in hibernation mode for 5 months and weather is oft times dreary and damp - longer battery lifeThumbs Up
Direct Link To This Post Posted: 17 Mar 2021 at 6:53pm
Yessir!
But look at it this way, it could be worse. My family on my mother’s side are Yoopers from Ishpeming. Now that’s some cold country.
I like SWVA. 73 was the high here today. We get enough snow to know when it’s winter, and enough heat to know when it’s summer, without freezing or sweltering for months or everything turning brown all summer. Just my opinion....
Direct Link To This Post Posted: 17 Mar 2021 at 7:01pm
By and large our weather in Western CO is beautiful. Just so happens that my back driveway, where my Pod sits, is in direct south-facing high desert sun. So the Pod bakes. But it was high 50s an sunny here today,  we had a bit or  rain earlier in the week while Denver and the mountains got 2+ ft of snow. I  prefer going to the mountains to play rather than living in them.
Direct Link To This Post Posted: 18 Mar 2021 at 6:29am
Even if your pod bakes in the afternoon the battery won’t get up to that peak afternoon temp because it has so much thermal mass. It will probably settle out closer to the daily average temp, as long as it’s in the shade. Now if it is in direct sunlight that’s another story... In that case even just painting the battery box white would help a lot.
