  New Posts New Posts RSS Feed: 196 water heater bypass
Topic Closed196 water heater bypass - Event Date: 23 Feb 2021
tewjax View Drop Down
Direct Link To This Post Calendar Event: 196 water heater bypass
    Posted: 23 Feb 2021 at 8:13pm
I found the water heater in my new 196, access panel under refrigerator, but only see one valve. Was told to look for three (hot, cold & bypass) but its pretty cluttered under there with the vacuum and all. Any help would be appreciated as I'm ready to de-winterize. What should I be looking for?
Tim & Diane, 2020.5 R-Pod 196
2007 Chevy Avalanche
2018 Honda Pilot AWD
2 Poms (Munson & Georgia)
Direct Link To This Post Posted: 23 Feb 2021 at 9:04pm
Some of the newer systems only use one valve. If you only see one, then that is what you have. If you switch it and start to add water, you should be able to hear water going into the water heater tank. You can check by opening the pressure relief valve on the outside. Your dealer should have showed this to you on the walk-through. If they didn't, shame on them. You may want to call them to ask.
Ricktoon View Drop Down
Direct Link To This Post Posted: 23 Feb 2021 at 11:38pm
Our 196 has two valves under the fridge. One is for the cold water and another for the hot. It has a tag showing what needs to be done.Both poiting in toward water heater for normal usage.
Rick and Ellen B
2019 Chevy Colorado
2021 Rpod 196
Direct Link To This Post Posted: 24 Feb 2021 at 9:50am
Thanks for the photo and comments. Your compartment is certainly less cluttered than mine. Maybe I can clean it up. Do you have a vac set-up?
Direct Link To This Post Posted: 24 Feb 2021 at 10:15am
Yes we have the vacuum. Sits below the compartment with water heater. A bright light helps to look sound inside. I put Velcro and handle on compartment door to improve access.
Rick and Ellen B
2019 Chevy Colorado
2021 Rpod 196
Direct Link To This Post Posted: 24 Feb 2021 at 10:16am
BTW. The photo is turned 180 degrees because the tag was attached upside down.
Rick and Ellen B
2019 Chevy Colorado
2021 Rpod 196
mjlrpod View Drop Down
Direct Link To This Post Posted: 25 Feb 2021 at 7:04am
My 195 also has a tag on it showing the valve directions for bypassing. I think only some come like that as your only the second person I know that has it. Ergo: let no 2 pods be built the same lives on.
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Direct Link To This Post Posted: 25 Feb 2021 at 7:31am
I found my tag upon looking again so thanks to all. My access panel is about 5"x8" and opens to a cluttered compartment blocked by the vac and 2" vac flex hose. Also, water heater hose lengths appear excessive. You know, 18" where 10" would be adequate. I think a larger access panel and some cleaning up may be in order!
Pod People View Drop Down
Direct Link To This Post Posted: 25 Feb 2021 at 8:08am
That 18" hose MAY be the antifreeze take up line.  check carefully
Vann
Vann & Laura 2015 RPod 179
Direct Link To This Post Posted: 25 Feb 2021 at 9:49am
On my 196 the antifreeze takeup line is attached to the pump and is behind a panel in the front slide-side compartment. An area also good to check when de-winterizing. A valve there can be turned to put in antifreeze but turn it back to draw water from the fresh water tank.
Rick and Ellen B
2019 Chevy Colorado
2021 Rpod 196
