List Your Mods: |
Page <1 6869707172 79> |
Topic: List Your Mods:Posted: 16 Jan 2020 at 7:10pm |
Interesting looking battery monitor. I just upgraded my battery to LiFePO4 and as part of the new installation, put in a battery monitor. The face on mine is round. I am awaiting an extension cable that I need to be able to put it where I want it to be. The write up is in my mods (see link in signature). I like your shelves. but I could not get away with multiple shelves in the wardrobe. My wife like to hang things up in there. I did get one shelf in, just high enough to separate the hanging items from where she keeps her toiletries bag and other small items. I have not yet opted for solar. We have a generator as there are times I have needed the hgher power to run the AC, something that is not feasible with solar yet.
teenab160
Joined: 31 Aug 2020 Location: Nebo, NC Online Status: Offline Posts: 2 |
Posted: 12 Sep 2020 at 6:57am |
Can you give me the dimensions for the tall pantry type shelves? Also did you attach it by the slide out or on the slide out? I am always looking for ways to add storage.
teenab160
Posted: 26 Sep 2020 at 7:00am |
Can you give me the dimensions to the pantry that you built? Also, did you attach it to the wall beside the slide out? If so what did you use? The walls are so thin that I’m afraid it won’t hold.
Thank you Teena |
Colorado
Joined: 18 Nov 2018 Location: Colorado Online Status: Offline Posts: 3 |
Posted: 13 Oct 2020 at 10:11am |
For Boondocking: 12 Volt improvements: Living in Colorado we prefer never to be plugged in. We made four electrical modifications which are very handy. 1. Installed 2200Watt inverter under dinnette with remote switch. 2. Installed a 30 amp automatic transfer switch, Go Power! TS-30 30 Amp Automatic Transfer Switch,(where the where the shore power comes into the camper under the sink (on the Model 178). The shore power runs to the transfer switch first, as does the power from our 2200Watt inverter. When the trailer is unplugged, all AC receptacles work off of the inverter. One has to turn off the breakers for the AC, Converter and Water Heater with this arrangement (since all of those appliances draw too much power, and in the case of the converter you would be using inverter power to charge the batteries)3. Purchased a 160 watt flexible Renology Solar panel and wired a plug to the front of the trailer running to a Duo Solar Charge controller
(wired independently to the two batteries. The solar panel is wired to a 50' cord so the panel can be placed in the sun while the camper is in the shade. The solar charger charges each battery independently. I did not use the Zamp plug on the back of the trailer (which is wired in reverse so one has to pay twice as much for an inferior Zamp system) 4. Installed battery selector switch which allows one to turn off the batteries (for storage), select battery #1 or battery #2 or "both".
Colorado
Posted: 13 Oct 2020 at 10:38am |
I was looking at that Giandel. How long have you had it and how is it working for you? I assume the largest ac load you are running is the microwave? How does the inverter handle that?
Hopefully you installed some heavy gauge conductors (and the appropriate battery fuse/cb) to the inverter as you could have upwards of 200A current there at full load.
MelissaJoy
Joined: 12 Oct 2020 Location: Michigan Online Status: Offline Posts: 16 |
Posted: 26 Nov 2020 at 9:28am |
![]() I bought an 2015 178 this fall and have spent the last few months completely remodeling it. It is pretty much finished, and we are heading out this weekend for a last minute trip to Tennessee. I changed the sink faucet, used peel and stick tiles in the bathroom and kitchen area, used rustoleum countertop paint for the kitchen counter and table, used hand towels for the curtains, added shelving, put hinges and cabinet openers on the benches, have new peel and stick flooring, and have large baskets underneath the benches for food storage. ![]() ![]() ![]() ![]() ![]() ![]() Here are the links to the items I used, I also used peel and stick grout to help cover the rough edges and keep the water from going behind the tiles. *update, this fell right off.
https://smile.amazon.com/gp/product/B07HRLYZD3/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1 White tiles *these did not stick well in bathroom, they did better in the small kitchen area. After the winter, a lot were separated from the wall. I have been pushing them back on, and I am wondering how they will do in the heat. https://www.wayfair.com/home-improvement/pdp/art3d-11-x-11-pvc-peel-stick-mosaic-tile-dtar1285.html mosaic tile *this tile stayed on pretty well. I am happier with it that the subway tile. https://smile.amazon.com/gp/product/B000BQS4AG/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1 peel and stick grout *update fell off. https://smile.amazon.com/gp/product/B07X65DXQT/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1 hooks to hold up curtain rods *did not work well on the wallpaper sections. They pulled down the wall paper. I switched to small, screw in hooks to hold up the curtain rods. https://smile.amazon.com/gp/product/B07CPBKQXY/ref=ppx_yo_dt_b_asin_title_o00_s01?ie=UTF8&psc=1 little shelf and hooks for keys for above TV area https://smile.amazon.com/gp/product/B07PWV8T39/ref=ppx_yo_dt_b_asin_title_o04_s01?ie=UTF8&psc=1 new shower curtain https://smile.amazon.com/gp/product/B086ZDB3DW/ref=ppx_yo_dt_b_asin_title_o05_s01?ie=UTF8&psc=1 floating shelves https://smile.amazon.com/gp/product/B07PKNZN1H/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1 soap dispensers *these too fell off. I reordered a shelf to hold things that will screw in. Adhesive installation doesn't work over peel and stick tiles.' https://smile.amazon.com/gp/product/B0759KM3P2/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1 shelf for over microwave and bed https://smile.amazon.com/gp/product/B08BSQ84QF/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1 flooring *It seems like the flooring has expanded a little, so some of the tiles are lifting a little. https://smile.amazon.com/gp/product/B075MMMMFT/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1 wallpaper https://smile.amazon.com/gp/product/B01AHHCHBK/ref=ppx_yo_dt_b_asin_title_o05_s01?ie=UTF8&psc=1 lid supports for under bench storage https://smile.amazon.com/gp/product/B07XYQ59CF/ref=ppx_yo_dt_b_asin_title_o01_s02?ie=UTF8&psc=1 faucet I got the paint at home depot, also took some trips to our local Home Goods store for the towels and other things for the kitchen area. I also took out the back of the cabinet under the sink to have a lot more room for storing pans, etc. |
EchoGale
Joined: 10 Mar 2019 Location: FL Online Status: Offline Posts: 469 |
Posted: 26 Nov 2020 at 9:45am |
Wow! That's beautiful.
Julie
Posted: 26 Nov 2020 at 11:36am |
Yes, it definitely brightens up the interior. I like your "tiled" bathroom. What did you use for that?
MelissaJoy
Posted: 26 Nov 2020 at 12:16pm |
Jenga Jack
Joined: 12 Apr 2016 Location: Southern Oregon Online Status: Offline Posts: 73 |
Posted: 26 Nov 2020 at 2:19pm |
Great mods MJ. Very impressive! For the floating shelves in kitchen area, how do you secure the screws into the wall to hold the weight of shelf and contents?
2014 R-Pod 178 aka the "Kobra Pod"
following a 2015 4Runner wherever it may wander |
