  New Posts New Posts RSS Feed: Winterizing using air compressor
Topic ClosedWinterizing using air compressor
poston View Drop Down
Direct Link To This Post Topic: Winterizing using air compressor
    Posted: 11 Nov 2020 at 7:24am
Originally posted by StephenH
How does everyone else get more of the water out of the tank?
A little water left in the tank isn't an issue.  The problem with water freezing is that it expands.  Freezing water in the tank has plenty of room to expand.
Freezing water in the toilet valve or faucets has no room to expand, so it breaks things to make room.
Jim
Virginia City, Nevada
2016 R-pod 180
2023 R-pod 153 BEAST MODE!
2015 Nissan Xterra
Direct Link To This Post Posted: 11 Nov 2020 at 5:11am
We all know that by simply draining the FW tank there is probably a gallon or three that don't make it out the exit hole.  What I have done beside the good ideas listed above is to take the pod for a ride around town with the drain hole left open.  Stopping, left and right hand turns, ect help immensely in ridding the residual water that likes to remain.  Fortunately there are some pretty good hills on our 20 acres so the best thing that works here is to park the pod on a hill with the drain on the low side.  This takes care of nearly all the water.
Direct Link To This Post Posted: 10 Nov 2020 at 6:34pm
A little water in the bottom of the tank will freeze but not be a problem. I just leave the tank drain open and look to see that the level is below the bottom of the pump suction line and if it is I call it good.
Direct Link To This Post Posted: 10 Nov 2020 at 6:14pm
The problems with the tank include:
Drain off center making not the lowest part of the tank due to the sagging of the tank from the weight of the water.
Pick up for the pump also not at the lowest part of the tank. It pulls air long before the tank is empty.
I have found that it helps to either:
Park the RPod so that the drain is lower than the other side of the tank.
Use a board and jack to push up on the bottom of the tank so that more of the water can reach the drain.
Anyway, there may be other creative solutions out there. How does everyone else get more of the water out of the tank? And no, saying that you never fill the tank is not a valid answer. Smile
Direct Link To This Post Posted: 10 Nov 2020 at 5:49pm
To be honest I have had that happen. Normally the pump won't pick it up but it could. I noticed the other day, moving my Pod with drain open, water was still in tank. End of the day we have to know our own circumstances and there might not be a standard answer. Got to know your own stuff.
vbdomenico View Drop Down
Direct Link To This Post Posted: 10 Nov 2020 at 5:25pm
As the amount of water that blew out after I turned on the pump was fairly high, I am starting to think that maybe there was still some water in the fresh water tank even though the drain was open.  The pod was fairly level but not perfectly level.
Direct Link To This Post Posted: 10 Nov 2020 at 4:53pm
Jato, +1, I have not found a lot of water in the pump either, the system is open, drained and pressurized with air. I drain my FW tank every year and the water heater is drained. I suppose water can be in the line from pump to tank, but not found that to be the case. Air pressure has been fine for me for 5 years.
Direct Link To This Post Posted: 10 Nov 2020 at 4:43pm
What do you mean by the "strainer bowl"?  Is this part of the pump?
Direct Link To This Post Posted: 10 Nov 2020 at 4:37pm
Originally posted by vbdomenico
I then did one thing that many of the directions I read online didn't mention - I turned on the water pump while the air was still hooked up.  I was surprised to see how much additional water came out, it appeared to be at least a half gallon.  Is this the water sitting in the pump and the line to the fresh water tank?  I assumed most of this water drained out when the system was depressurized.
[/QUOTE
That is very interesting as I have used air on our 177 for the 9th year.  Have never thought of turning the water pump on, yet have never suffered a leak or break the following year.  For a few years I never even checked the strainer bowl, then did for about 3 years and would observe 1 or 2 drops inside the bowl.  Have never checked the bowl since.  Seems to work here in northern Michigan where real cold winters
That is very interesting as I have used air on our 177 for the 9th year.  Have never thought of turning the water pump on, yet have never suffered a leak or break the following year.  For a few years I never even checked the strainer bowl, then did for about 3 years and would observe 1 or 2 drops inside the bowl.  Have never checked the bowl since.  Seems to work here in northern Michigan where real cold winters happen.
Pod_Geek View Drop Down
Direct Link To This Post Posted: 10 Nov 2020 at 12:00pm
Originally posted by mcarter
I have used air for 5 years, I never bypass my water heater, I do however, drain and clean. The only reason to bypass water heater is if injecting anti freeze, you don't want to fill water heater with 6 gals of anti freeze. The lines will blow fine with air.
Same here.  After blowing out all the lines (don't forget the outdoor shower if applicable!) I do remove the little plastic plug that I replace the anode rod with.  A bit more water typically drains out.  I replace it and open the low-point drains one more time.
I then pour pink stuff into all drains and this time I also poured a gallon into the black tank via the commode.  I think that last part is optional.
2020.5 R-Pod 195 Hood River
2018 RAM 2500 6.4L
