  New Posts New Posts RSS Feed: sink water pressure
Topic Closedsink water pressure
Badweissenbier View Drop Down
Direct Link To This Post Topic: sink water pressure
    Posted: 30 Oct 2020 at 6:50pm
Yea my 190 has the same pressure on both sinks, the shower indoor and out and the extra outside cold water sprayer.
It really sounds like your aerator or the faucet valve itself.
ronnieb View Drop Down
Direct Link To This Post Posted: 30 Oct 2020 at 7:24pm
I've checked the aerator several times...seems fine. When you say faucet valve, do you mean part of the cold water handle? To get to the underside of the entire faucet involves taking the sink out. Ugh.
Direct Link To This Post Posted: 31 Oct 2020 at 6:11am
Ok I had to go look at a video, I did not realize you had 2 separate valves as up to now all the pods I’ve seen had 1 common valve for both hot and cold. I wonder if your hoses are getting pinched somewhere. I find it hard to believe both hot and cold valves would have problems. Is your water heater and pump in the front under the bed? Do the lines run near the slide out? Just thoughts
JR View Drop Down
Direct Link To This Post Posted: 31 Oct 2020 at 8:31am
Just a thought you might want to remove the aerator from the of the faucet and see if with the aerator removed is your water flow what it should be?  If it is then you know what the culprit is and if the flow is still just a dribble then look at replacing the faucet.
Jay
179/2019
Direct Link To This Post Posted: 31 Oct 2020 at 9:58pm
You may just need to disconnect the faucet and backflush it to clear the valve. You may need to put a container under the line and flush out any trash that is in there.
