Page <1 34567> |
podwerkz
Topic: AggravationsPosted: 07 Oct 2020 at 12:49pm |
I hate motels. They will have to pay me to sleep in one from now on. Of course, that wont happen so we are back to square one.
I hate motels.
Posted: 07 Oct 2020 at 6:24pm |
I’m not sure about the Chesapeake Bay bridge as I haven’t taken the rpod over that one. The 64 and the 664 bridges between Hampton and Norfolk both require you stop and show them it’s off. Not a big deal unless you want to run your fridge on propane, then you have to find somewhere to pull off after the bridge to turn it back on. It’s really the tunnels not the bridges sections. Propane settles so they are concerned it will stay in the tunnels if there is an accident and a leak occurs. The tunnels are there so that the Navy won’t get bottled up in the event an enemy attacks the bridges. |
RoverPod
Joined: 07 Mar 2020 Location: Virginia Online Status: Offline Posts: 118 |
Posted: 07 Oct 2020 at 7:06pm |
Just a note that the Chesapeake Bay Bridge (which is in Maryland) and the Chesapeake Bay Bridge Tunnel (which in is Virginia) are two different things. But yes, at the CBBT, you just let the toll taker that your propane is turned off. At the HRBT, you have to pull into the inspection station and tell them that your propane is turned off. They write down your license plate number on their log.
2017 F150 XLT SuperCab
2020 rPod 180 |
Posted: 08 Oct 2020 at 6:41am |
Yeah thanks, I forgot about the bridge up in MD. HRBT and MMMBT (Monitor-Merrimack Memorial Bridge Tunnel, had to look up the official name) require stops for propane inspection. I guess the CBBT considers the toll booth to be the stop?
pedwards2932
Joined: 21 Sep 2020 Online Status: Offline Posts: 333 |
Posted: 08 Oct 2020 at 6:43pm |
Got my Hayes Sway Master in today.....it was new in box. Not sure about warranty since it was an e-bay purchase? I also purchased a Sherline scale for tongue weight so I can accurately weigh tongue weight. I have the Curt Better Weigh but I am not convinced it is very accurate. It sure didn't weigh total weight very well.....it was off by 1000 lbs.
Posted: 08 Oct 2020 at 8:48pm |
I think you will be okay with the Hayes. Please check with Hayes to make sure it is one that is newer or if older has had the recall applied to it. See this for details. If you had purchased direct from Hayes, it would not be an issue, but I have no idea how old the unit you purchased is since you say you purchased it on ebay.
pedwards2932
Posted: 08 Oct 2020 at 9:05pm |
Thanks for the info....will check it out. I think since other companies sell them I should be ok. You actually can't buy it direct they send you to retailers
pedwards2932
Posted: 09 Oct 2020 at 8:37am |
Contacted Hayes and the unit I have will work fine with my Escape. The issue/recall is for vehicles with integrated brake control. Hayes will do the upgrade for free. I think I may wait until I am done with using my r-pod this year as it takes about a 2 week turnaround. Thanks for the heads up.
Posted: 09 Oct 2020 at 9:59am |
I had bought it and got the recall notice. Mine is upgraded. I'm glad you found out.
pedwards2932
Posted: 09 Oct 2020 at 10:30am |
I think we will probably use the camper up to December and I will send it back then. There is no issue with using it.....just want the upgrade in case I sell the trailer. I used my Sherwood scale and the tongue weight is 450. That scale works good no issues, I would recommend it. I know my trailer hitch is rated for 350 lbs so I will need to redistribute to get it closer to 350. Shouldn't be too hard to do.
Page <1 34567> |
