  New Posts New Posts RSS Feed: Potable antifreeze change after a year?
Topic ClosedPotable antifreeze change after a year?
geewizard View Drop Down
Direct Link To This Post Topic: Potable antifreeze change after a year?
    Posted: 06 Oct 2020 at 8:54am
Sounds good, thanks.
2004 Outfitter Apex 8 camper
2014 Toyota Tundra DC
Direct Link To This Post Posted: 05 Oct 2020 at 8:21pm
If you just had a half cup of bleach sitting in the bottom of the tank it wouldn't stop stuff from growing elsewhere in the tank. I'd wait till spring and then do a fill with some bleach, drain, flush, and refill.
Direct Link To This Post Posted: 05 Oct 2020 at 8:01pm
Thanks for the input.
Now, I'm concerned about the fresh water tank growing mold.  I think a half cup of bleach might be a good idea.
Thoughts on that?
Direct Link To This Post Posted: 05 Oct 2020 at 6:37pm
Antifreeze doesn't 'break down' but as Grant states correctly above, it can and will evaporate.  I would highly doubt it would do so in a closed system as in the H and C water lines but is probable in an open condition as in the sink and shower traps.  One of the houses I winterize in northern Michigan will get the RV antifreeze in toilets and all traps this month.  By the time I open things up come May it is easy to see how much as actually evaporated in the toilet bowls, usually 1/2" over 6 to 7 months.  Your call geewizard, I would pass on the water lines but may throw some in the traps.  Even if you didn't, the worst that could happen would be a "smell" from your gray or black water tank if all did indeed evaporate from the trap.
I use compressed air  and after that quick process is complete I measure out a total of 16 oz. RV antifreeze for 1 shower and 2 sink traps and use a little bit for the top of the toilet seal to keep the seal moist during the winter months.  The last time I purchased a gallon RV antifreeze was 2012 and the price marked was 79 cents - 1 gallon will last 8 years.  Curious to see what it sells for now, will probably purchase a gallon later this week.
Grant177 View Drop Down
Direct Link To This Post Posted: 05 Oct 2020 at 3:02pm
There are notes I see that it can evaporate (albeit slowly) but that it lasts longer than 1 year as well.  That said, I would probably spend the $5, pump a little more through the system and dump a little more in the drains.
Grant
2011 R-Pod 177
Direct Link To This Post Posted: 05 Oct 2020 at 2:26pm
I haven't used my RPod since last fall so now it's been a year since I filled the water system with potable antifreeze.  And I have no plans to use the RPod until next spring at the earliest....when a Covid-19 vaccine is available.
Do I need to change it since it's a year old?
