  New Posts New Posts RSS Feed: Slide out
Slide out - Event Date: 18 Sep 2020
Debravz View Drop Down
Post Options Post Options   Quote Debravz Quote  Post ReplyReply Direct Link To This Post Calendar Event: Slide out
    Posted: 19 Sep 2020 at 11:39am
Just purchase a 2020 189    Very excited.
First of many questions: I don’t seem to have papers for the care and upkeep of the slider.
Are there any specifics I need to know?
Thanks
Debbie and Tom
2020 189
2012 Chev Silverado
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2020 at 2:53pm
Hello and welcome Debbie! I hope you have many fun adventures and make many great memories with your R-Pod 189. We have the 179 and have really enjoyed it.
As for the slide-out, the Internet is your friend. Two things to take care of are to treat the rubber with a product like Protect-All Rubber Seal Conditioner and to lube the track with a good quality spray lubricant. Do that, and you will be fine.
Mooree View Drop Down
Post Options Post Options   Quote Mooree Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2022 at 7:04am
The rust, the dust particles, the dirt, and the snow are but some of the elements that accumulate on some components of the slide-out. When such elements mix and are untouched for a long time, a build-up of some sort occurs that causes slide-outs to get stuck. The Slide-Out Lubricant for Slide-Out from SMART STRAW is the right choice and can help you keep your rig’s retracting system in top shape. It reduces the friction that occurs when a build-up of dirt or corrosion occurs in the window. It is also able to take on such debris and make it easier for you to clean it out of the problematic areas.
Post Options Post Options   Quote Mooree Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2022 at 10:13pm
A travel trailer with a slide-out will make you feel at home without staying in cramped corners. An RV extension with a slide-out will surely bring you certain benefits. The normal width of a camper van is 8 feet wide, including the slide-out in place; each slide contributes roughly 1 1/2 inches of the area when open, which adds up to 3 feet in total of extra space that enables seats to be converted into beds for sleeping.
MoPod View Drop Down
Post Options Post Options   Quote MoPod Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2022 at 7:59am
What?????
Bill & Nancy
2015 RPod 179
Previously 2010 RPod 176
2014 Explorer Sport
