Page 12> |
drdrew
Joined: 14 Jan 2011 Location: missouri Online Status: Offline Posts: 88 |
Topic: stupid question...amps?Posted: 11 Feb 2011 at 1:29pm |
when reserving sites, how many amps do i need? 20,30,50? can i get too many amps and not be able to hook up?
172T
pmjensen
Joined: 17 Aug 2010 Location: South Texas Online Status: Offline Posts: 179 |
Posted: 11 Feb 2011 at 1:47pm |
Normally either 30 or 50. If it is a 50 amp hookup you will Need an adapter http://rvbasics.com/techtips/50-to-30-amp-adapter.html. I pickuped one at our local Walmart, although not all Walmarts carry RV Stuff. If it's a 30 just plug it into the power post.
2011 R-176 Nuestro Pod
2014 Silverado |
Outbound
Joined: 19 Nov 2009 Location: Oshawa, Ontario Online Status: Offline Posts: 767 |
Posted: 11 Feb 2011 at 2:22pm |
Your trailer is wired for 30 amp service, but you can choose any of the three sites you've mentioned. However, you may need an adapter.
20 amp sites - and the same thing for 15 amp sites too - have standard outlets like you have at home that you'd plug a lamp into. Using an adapter (like this one), you can plug your trailer in. You will have to be a little careful with the high-wattage appliances, tho, otherwise you'll throw a breaker at the campground post. If you want to use the micro/convection oven, you'll have to turn off the A/C first and vice-versa. If a hairdryer and curling iron are plugged in, the A/C and microwave must be turned off. But, its not much of a sacrifice to hook up to 15 amp service. For 30 amp sites, just plug in and you're set. On 50 amp sites, its common to find power posts that have 30 amp plugs too (plus 15 amp); just plug in and you're set. However, you can't expect to always find a 30 amp plug on a 50 amp site, so you may need an adapter (like this one). When buying an adapter, I suggest that you stay away from the wall-wart style (like this one or this one) and stick with dogbone-style ones like I've linked above. The cheap wall-warts tend to heat up with heavy use of the A/C. The dogbones hang neater of the campground plug and are less likely to pull out naturally or should someone trip on the power cord.
drdrew
Posted: 11 Feb 2011 at 2:52pm |
thank you for the helpful info!
172T
TerryM
Joined: 16 Nov 2009 Location: Saint Augustine Online Status: Offline Posts: 1950 |
Posted: 11 Feb 2011 at 7:06pm |
Without an adapter you can't plug into 50amps so there is nothing to worry about. Its mistake proof.
Terry |
TerryM
Posted: 11 Feb 2011 at 7:12pm |
I just thought of something. With an adapter you can plug into 15/20amp house style outlets. It is always a good idea to have one of them. You can run most things in the camper with that amperage. Not the AC but all your lights, TV, radio etc. I THINK you can even run the microwave as long as you don't have much else running.
Terry |
drdrew
Posted: 11 Feb 2011 at 8:59pm |
Thanks already got one of dem :)
172T
Joined: 29 Jul 2009 Location: MD Online Status: Offline Posts: 9066 |
Posted: 11 Feb 2011 at 9:44pm |
Here is a thread discussing the wattage of the various 'pod appliances. A 15 amp outlet can support a 1800 watt load and a 20 amp outlet can do 2400 - but ideally you should stay below that somewhat. |
drdrew
Posted: 14 Feb 2011 at 9:53am |
okay a couple more stupid ?'s...
does "full hook up" mean there is a sewer or something like that? also when a site says it has water, do i need to have my own connector hose to get the water into the pod? thanks again as always... |
172T
Goose
Joined: 24 Sep 2010 Location: Arizona Online Status: Offline Posts: 672 |
Posted: 14 Feb 2011 at 11:06am |
Yes, you do need your own water hose to hook up at a site. It is a good idea to have two hoses, one that you use only for your fresh water and one to flush your sewer lines. No question is stupid. Full hook up is water, electric and sewer. Goose |
Page 12> |
