Page <123> |
Calendar Event: New RPoders in the Wolverine StatePosted: 05 Aug 2020 at 9:41am |
Hooking up the TV and running it to get the trailer battery voltage up should get the slide in. But as others have said, running your batteries down like that is bad for them. Do it more than a few times and you’ll need new batteries.
Posted: 05 Aug 2020 at 12:40pm |
Welcome and congratulations on your "new to you" RPod. I hope you have many fun adventures and make many great memories with it. I agree that if your Cherokee is set up right, it will charge the battery/batteries. What it may or may not do is be able to both charge the battery and run the refrigerator on 12V at the same time. Many vehicles just don't have the capability to do so. We have run the refrigerator on propane for most of the time we have been traveling with our 179. Only recently, I installed an LiFePO4 (Lithium Iron Phosphate) battery instead of the two 6V batteries in series that I had been using (see my mods for details). I also installed a DC to DC charger and a dedicated circuit in our Frontier and can now both charge the battery and use the refrigerator on 12V DC. LP is still the way to go when not towing though as the refrigerator will discharge the battery/batteries rather quickly. I also got a Renogy 100W Solar Suitcase with Voyager controller (again, see my mods for details). I got it on sale which was helpful. It is still more expensive than some other options, but it works well and I am pleased with it. As stated above, I would not go below 100W. Going with a 200W would have been nice, but the size and cost of the larger unit was higher than I wanted to pay. I have the connections to either use the solar port or a connection I made on the tongue with PowerPole type connectors. One other thing I did recently was to pick up a Firman dual-fuel (gasoline or propane) generator from Costco. I don't know if it is still in stock but if so, it is much less expensive than a Champion or other dual-fuel generator brands. It is electric start and has a multi-function meter to track hours for maintenance (something the Champion lacked when I was looking). It is relatively quiet. It is on sale right now. http://www.costco.com/firman-2900w-running--3200w-peak-electric-start-gasoline-or-propane-fuel-powered-inverter-generator-gas-and-lp.product.100481637.html It delivers a little less power on propane than on gasoline, but it is easier to carry a second propane tank and not worry about gasoline fumes or spilling. It is powerful enough to run the AC. The down side is that it is quite heavy. I had made a lot of these changes to prepare for a trip to Alaska which did not happen this year. I hope we can make it next year instead. In the meantime, we are much better set up for off-grid camping. Since you are experienced tent campers, I think you will be well pleased with the luxury of your RPod.
PilotPodder
Posted: 05 Aug 2020 at 1:30pm |
Congrats on the new-to-you R-Pod from yet another fellow Michigander! You will find excellent guidance from this forum as the contributors here have both extensive knowledge and hands-on experience. The counsel given above is outstanding as usual. I did read that although you are experienced with rustic camping, you are new to RVs. I would recommend taking your new-to-you R-Pod to a close-by State Park (not on weekends) sometime to plug in and check out that everything works well, as well as learning how to use the dump station. State Parks like Yankee Springs, Fort Custer, Waterloo, Algonac, and several in mid-Michigan are lightly populated during the week. I also have several videos for those new to R-Pods in the link below if interested. All the best!
Phill-n- Dawn W.
Joined: 01 Aug 2020 Location: MI Online Status: Offline Posts: 10 |
Posted: 05 Aug 2020 at 8:02pm |
Thanks... I don't 'plan" to run the battery down that low. Just worried about a worst case scenario on our first trip out. Looking to add another battery and solar for future adventures.
jimandclare
Joined: 13 Apr 2016 Location: Erie, MI Online Status: Offline Posts: 96 |
Posted: 05 Aug 2020 at 9:40pm |
Put these rustic campgrounds on your list to try. Last week we were in the nicest rustic campground I've seen in the State. Rollways Campground in the Huron National Forest, which is north of Hale and west of Oscoda off of route 65. 19 sites of which most are first come first serve. Showed up on Monday and we had the place to ourselves for the first two nights. East of Rollways at the Lumberman's Monument is Monument Campground. It's really nice under tall pines and we're heading there next.
Jim & Clare
Phill-n- Dawn W.
Posted: 06 Aug 2020 at 7:09am |
Thanks! Those sound wonderful. I looked at Lumberman's Monument on-line. I'll check out the other as well.
You might consider Shoepac or Tomahawk Lake located off 33 between Atlanta and I away. |
jimandclare
Posted: 06 Aug 2020 at 7:27pm |
Also thanks. Will check them out.
Jim & Clare
7mm sendero
Joined: 21 Dec 2019 Location: Forest Lake, MI Online Status: Offline Posts: 22 |
Posted: 13 Aug 2020 at 7:18pm |
Kewadin? That's where I grew up, very cool. We picked up a 182G in December, were we lucky to get it when we did.
A checklist is a great idea, however after my first trip I was amazed how easy an R-Pod is to setup and take down.
Phill-n- Dawn W.
Posted: 16 Aug 2020 at 3:12pm |
Thanks all for the advice and encouragement. Just got back from our first trip and it went nearly perfect.
I ended up using twin 12v batteries in parallel. A battery monitor said I stayed at 12.6v or better. (Not sure how low I could go, so I stayed conservative) No we look forward to future adventures with growing confidence and dreams of future mods. Hope to see you on the roads or in the forest! |
JR
Joined: 31 Aug 2018 Location: Manistee, MI Online Status: Offline Posts: 408 |
Posted: 16 Aug 2020 at 7:24pm |
So I am holding my breath where did you end up on your maiden voyage, and did it have all the amenities or was it boondocking? So many places to discover in Michigan.
Jay
179/2019 |
Page <123> |
