Page <1 678910 11> |
fwunder
Topic: SOCPosted: 25 Jul 2020 at 7:41pm |
After bending down to chase after all the pieces for a few years, you learn that those WV farmers had some good ideas. I lived in SW Virginia for 6+ years - Blacksburg.
Posted: 25 Jul 2020 at 7:44pm |
Blacksburg is where I am now, well Christiansburg next door. I used to live in the eastern panhandle of WV but never came across the old tire trick. Thanks for that!
fwunder
Posted: 25 Jul 2020 at 7:53pm |
So funny. Small world stuff !!
Olddawgsrule
Joined: 20 Sep 2017 Location: New Hampshire Online Status: Offline Posts: 1014 |
Posted: 26 Jul 2020 at 7:02am |
Ha.. I learned it from my Grandfather who did it in Newfoundland. Not just a WV thing! Between that and the Kindling Cracker life is good! Well, the splitter as well...
ToolmanJohn
Joined: 23 Apr 2014 Location: Connecticut Online Status: Offline Posts: 451 |
Posted: 26 Jul 2020 at 11:02am |
Solar is awesome!!
On my STECA SOLARIX PRS 2020 20A charger controller (150 watt rook mount panel) the chart for voltage levels is:
End of charge voltage (float) 13,9 V Boost charge voltage (boost) 14,4 V Equalization charge (equal) 14,7 V (MONTHLY) The equalization charge only happens every when there's enough solar power to do so. This is on 2 Trojan T-105 6 volt golf cart batteries in series (12 volts). There must be an internal clock keeping track of when it happens. The solar charge controller is directly hooked to the batteries, regardless of whatever the charger/converter is doing, the solar does it's thing when it decides to do it. Which is nearly 100% of the time. I only plug into shore power at home when prepping for a trip (cooling fridge on electric, or running the A/C while cleaning inside the camper). It looks like the Renogy solar controller might have a similar feature, but stuck on equalization? I have had my batteries installed in the trailer (mine are in the trailer nose, not an R-Pod), always check water levels before storage, and left alone all winter to take care of themselves. So far results are great. Just a little water to add each spring. Solar is awesome!! |
fwunder
Posted: 26 Jul 2020 at 11:43am |
Yeah, I am sure the tire method was invented shortly after the wheel was. Now I have to have that Kindling Cracker!! I thought I was hip with my Fiskars 28 inch hookaroon! ![]() |
fwunder
Posted: 26 Jul 2020 at 11:49am |
Modified version of panel mount/stand is much stronger. Shortened legs, glued it up, added some bracing with pvc blocks and vhb tape and added a simple preventer with paracord and trucker's hitch to keep it from collapsing. It's easier to adjust than the Renogy suitcase. I think this will work. ![]() ![]() |
fwunder
Posted: 26 Jul 2020 at 11:54am |
Thanks John. I may have accidentally somehow reset the controller. I swapped battery and solar connections. Yes, I have them clearly labeled. Just wasn't paying attention. Anyway it complained about battery overload. When I hooked it up properly, it seems it may be functioning better. At least, when side-by-side with new controller. I have detailed all of this to Renogy. It would be nice to hear from them. |
Posted: 26 Jul 2020 at 12:45pm |
I'd recommend against placing pressure on the backs of the cells like that, they can develop fractures really easily. You won't see them but they will eventually degrade electrical performance. The frame is fine, you can just outboard the mounting legs to the corners, and drill holes in the frame where you want them The inboard holes are there so the modules can be mounted to handle really heavy wind and snow loads which you will never see in a portable application.
I would guess that the controller just resets when you disconnect it from battery power. One of the software versions warns against having a load on the batt during equalization because it can get stuck if that's happening, not sure which version was causing the issue originally at this point. Anyhow in gel/AGM mode it will never equalize so problem solved. You don't need both controllers to equalize anyhow.
Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2792 |
Posted: 26 Jul 2020 at 1:34pm |
OG is right. You should not attach anything to the backs of the panels. Use the frame. Another thought I had is that you might want to use schedule 80 PVC for the frame. Walls are a bit thicker & stronger. However, if you feel it's strong enough now, there's no need to add weight.
