  New Posts New Posts RSS Feed: TVs and antenna
Topic ClosedTVs and antenna
paddlewhisp View Drop Down
Direct Link To This Post Topic: TVs and antenna
    Posted: 23 Jul 2020 at 7:29pm
Thanks y’all.
Paddlewhisp
Direct Link To This Post Posted: 23 Jul 2020 at 7:34pm
That ant has 12V that energizes the amp when the amp button is pushed, if the red light comes on, and you have 12V to the amp wire, the amp may not be working. That will be your problem. You will get no reception without amp. The amp is in the ant. Best to just replace, they are not that pricey.
Direct Link To This Post Posted: 23 Jul 2020 at 8:21pm
This is the antenna I purchased after I broke the 2nd batwing antenna: https://smile.amazon.com/gp/product/B010SP0IY4/. I bought it because the base was the same as what was already there so I did not need to remove the base which was still in good shape. Unfortunately, it is not available on Amazon, but may be from other sources.
This one looks similar, but the base may need to be changed:  https://smile.amazon.com/Magnadyne-RVTV-W2-SEPARATE-F-CONNECTOR-CONNECTIONS/dp/B00USE3JF6/.
Both of these come with a new wall plate. You may find that you might need additional wiring if the existing wiring won't quite reach the connections on your stereo unit.
Direct Link To This Post Posted: 23 Jul 2020 at 8:29pm
Thanks for the information
Paddlewhisp
Direct Link To This Post Posted: 24 Jul 2020 at 11:47am
I used same antenna as SH, only in black.
mjlrpod View Drop Down
Direct Link To This Post Posted: 24 Jul 2020 at 12:10pm
I have not seen anywhere that the OP has said that they are turning on the antennea booster switch. You MUST have the booster switch on, before seaching for channels. It's a tiny little button on the wall behind the t.v. . You push it in, a red light, lights up. Have you turned on the booster ???? Do you know where it is??
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Direct Link To This Post Posted: 24 Jul 2020 at 12:38pm
True, however numerous posts have mentioned that and at top of this page I told them how to troubleshoot, so at this point I'm assuming they know that.
Direct Link To This Post Posted: 24 Jul 2020 at 5:59pm
We have tried it on and off with the booster  ....  no luck
We called Forest River service and they are working to figure this out
Paddlewhisp
