 Post Reply Post Reply Page  <1 56789 88>
Chopperbob View Drop Down
Post Options Post Options   Quote Chopperbob Quote  Post ReplyReply Direct Link To This Post Topic: Pictures of tow vehicles and trailers
    Posted: 13 Jul 2020 at 7:35pm
@andyrpod190  Congrats!  We really enjoyed our first two days camping in it.  It was a breeze to tow behind the Honda.  And we gave it a good trial in the Appalachia of TN, NC, and VA!
Audio tape the walk through so you can refer to it later.
Marveling at the Design!
Andyrpod190 View Drop Down
Post Options Post Options   Quote Andyrpod190 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2020 at 7:19pm
Beautiful Pic!   Getting our 190 this week!
AC
Post Options Post Options   Quote Chopperbob Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2020 at 7:15pm
2019 Honda Ridgeline AWD pulling our new 191 near the Blueridge Parkway, VA.
Post Options Post Options   Quote marwayne Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2020 at 12:33pm
We bought ours in sept. 2010 it has the rings, the next new graphics came out about one month later
Grant177 View Drop Down
Post Options Post Options   Quote Grant177 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2020 at 12:01pm
I am not really sure....is there a specific build date on the factory stickers somewhere?
I purchased it at an auction last fall and this is our first season with it...if I recall, there was some confusion when I went to register it as the bill of sale had "2010" on it, though it's a 2011 model year....the person who wrote the bill up (at the auction house) was confused over the VIN #.
Grant
2011 R-Pod 177
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2020 at 7:31pm
Nice setup.  When was your 177 built?  Ours was built the 1st week of January 2011 and has the serengeti decals.  We were hoping to get the rings like you have, but thought it must have been discontinued after the 2010 year.
Post Options Post Options   Quote Grant177 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2020 at 1:48pm
Grant
2011 R-Pod 177
Post Options Post Options   Quote Andyrpod190 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2020 at 7:01am
Great info that I needed!
Thanks everyone!
AC
Post Options Post Options   Quote offgrid Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2020 at 6:31am
Originally posted by Andyrpod190
So I bought a Blue Ox WDH. Suppose to be the best. I have been told that without it in N.E. should be fine as the pickup I bought has built in anti-sway. Will try it without it and will put it on when going from NH to WY next year!
So this is a class IV receiver. Rated up to 12,000 lbs, but the pickup I have is at 7700 lbs towing capacity.
So really just trying to find the correct ball for the hitch. I know there are many types that go into the receiver and have adjustments, etc... depending on the application.
You need a 2 inch ball. It needs to have a rating at least as high as the heaviest trailer you want to tow, higher than needed doesn't hurt anything.
The nut needs to be tightened to 250 ft-lbs. which is a lot. They are notorious for getting loose if not torqued properly. So either you need to have it put on your Blue Ox at a shop or you can slide the hitch into the receiver sideways, put your box wrench on the nut, and carefully put your full weight on it. If you weigh 250 lbs stand 1 ft away from the nut, if you weigh 125 then 2 feet, 187 lbs then 1.5 ft, etc.  Its OK to go over a little.
Also, visually checking the ball for tightness should be part of your pre-tow checklist every time you hitch up.
crw8sr View Drop Down
Post Options Post Options   Quote crw8sr Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2020 at 8:41pm
We also use a Fastway E2 WDH (roundbar version) towing our RPod 190 with our Chevy Traverse.  Smooth and easy.
Chuck & Lyn
Izzy, Morkie. RIP
Zoe Joy & Gracie, Yorkie
2018 R Pod 190
2019 Traverse
