Page <12345> |
| Author | |||
Olddawgsrule
Joined: 20 Sep 2017 Location: New Hampshire Online Status: Offline Posts: 1014 |
Topic: Broken Welds on Floor JoistsPosted: 12 Jul 2020 at 5:25am |
I was speaking of you! She's doing the deed.
Posted: 12 Jul 2020 at 8:19am |
Old, I don't quite follow what you are saying when you say "I was speaking of you."
Do you truly think that if Belinda has Geoffrey's Welding and Farm Supply write a letter saying that FR did a lousy job on the aluminum welding that FR is going to pay any attention to it? I will give you 100 to 1 odds that they'd shrug, then send a nice letter back saying that they believe the problem was causedowner neglect and a lack of maintenance that they will not repair. If she hires Failure Analysis, Inc. at about $1000 an hour, I'm sure in at least 15 hours of careful field and laboratory examination, plus travel and lodging, she can show that the welds were probably tack welds and could have been done better. When FR gets the Failure Analysis, Inc. report, they will dutifully read it, admire the careful and thoughtful work, then send a letter back declining the repair because the trailer is out of warranty, is over a year old, was not purchased from an authorized dealer, and that the problem was caused by owner negligence and lack of maintenance. Belinda will be out maybe $15-20K and no better off than she was before she went to Geoffrey's Welding. Again, I could be wrong, and ususally am, but that doesn't seem like a very good way to spend one's money. You stated: "If this ever happens to you, give me a call. I'm come pick it up and get it off your hands." I suggested to Belinda in my post that she avail herself of your remarkably generous offer. Were you making that offer to her? Or was that just hyperbole that you were directing to me? Best if she could sell off the valuable parts, but given the age of the trailer, there isn't much besides the various circuit boards that is worth a lot as salvage. Your kind offer to haul it away is truly the optimum solution, if you were making it good faith, and she should avail herself of that opportunity. |
Posted: 12 Jul 2020 at 8:54am |
Nope, you are thinking about the construction as if it were an old school stick built house, but its not. The floors are a laminated diaphram system, look at just around 2 minutes into this video. The system depends on all the components working together to support the structure. The whole thing is glued together under pressure. The plywood is a crucial element, if it delaminates then the whole system fails. This is how the trailer manufacturers save weight (and not incidentally cost) but it makes the whole trailer much more susceptible to water intrusion. If you want to see the tack welding procedure its around 40 seconds in. There is no way tack welding that thin wall aluminum square tubing like that can carry the loads without the plywood glued to it. If you spent all the money on legal fees and expert testimony as LA referenced, FR would simply point out that this is normal construction practice in the ultralight trailer world and works fine unless the trailer has been neglected and water intrusion has occurred.
podwerkz
Posted: 12 Jul 2020 at 1:23pm |
Solution: Lots of full coverage insurance and a can of gasoline.
Posted: 12 Jul 2020 at 2:28pm |
Um, err, I kind of think that in countries that have the rule of law, insurance fraud and arson, not to mention unauthorized burning of trash, could be a crime, but perhaps I'm wrong again.
Maybe hauling it down to New Hampshire, abandoning it, and escaping back to Ontario might be the trick. If it'd make it to NV, heck, it'd fit right in with all the other trailers that have been abandoned. We drive by one every time we go into town.
Posted: 12 Jul 2020 at 2:41pm |
Dunno, rpods might be a little on the small side to be meth labs.
Posted: 12 Jul 2020 at 5:54pm |
They don't make meth in Dayton. That's in Silver Springs, 15 miles east of here. And rPods are perfect to store the chemicals and final product.
Posted: 12 Jul 2020 at 7:21pm |
Acetone, benzene, ethanol, ether, phosphorous, toluene. No gasoline required for those trailers, although that is sometimes used to cook meth too.
Posted: 12 Jul 2020 at 8:19pm |
What about ephedrine? I can't buy any more in our local Krogers (aka Smith's). They're too busy setting records on Oxycodone sales to mess with a stuffy nose.
Posted: 12 Jul 2020 at 9:41pm |
I think this drug making talk is not only irrelevant to the topic but to the forum. It doesn't help Belinda at all.
Page <12345> |
