Colt
Joined: 16 Nov 2019 Online Status: Offline Posts: 383 |
Topic: Shelf Over The BedPosted: 05 Jul 2020 at 5:58pm |
How did you attach your shelf and what did you make it from? There is so little in the walls, I'm not willing to just start driving screws. I searched, but apparently didn't hold my mouth right. I know I saw a thread on this somewhere.
John
'16 R-Pod 180 |
Woodmiester
Joined: 03 Aug 2018 Location: Greenwood IN Online Status: Offline Posts: 142 |
Posted: 06 Jul 2020 at 3:30pm |
I made mine from a ready made wooden closet shelve from Lowe’s. PERFECT for this.
I cut it to the correct length then installed a cleat to each wall for it to rest on. For the cleats, I glued them, let it dry then installed two screws through the cleats into the Wall. Do not use screws longer than 1 1/2 inch. I then used a couple of finish screws to secure the shelf to the cleats. For glue, I used liquid nails. Been there for two years, no problems!
Swampfox
Pod People
Joined: 22 Sep 2011 Location: Chapel Hill,NC Online Status: Offline Posts: 1091 |
Posted: 06 Jul 2020 at 6:25pm |
There are lots of ways-hollow wall fasteners, wide screws, glue, expanding screws are some ways. Most people use the window valence as a starting point. Metal angle brackets can be used also. I did my shelf differently. I went front to back instead of side to side. I have a 179 which has a wooden wardrobe that I can use as one end.I used a piece of wood on the other end. I used coarse threaded 1" screws and glued the wood to the ceiling. I cut the wood at the correct angle to match the slope of the ceiling. the other end is attached to the wood wardrobe end Hope this helps Vann
fwunder
Posted: 06 Jul 2020 at 6:46pm |
Did this back in 2013 and tens of thousands of miles. Still going strong.
