1liquid1
Topic: Stainless steel screwd Posted: 06 Apr 2020 at 12:34pm |
I need to know what size stainless steel screws to use to replace my old screws. And is there a u tube to show just where all the screws are?
Penny Greer
Buffalohunter
Posted: 06 Apr 2020 at 2:30pm |
A good hardware store would be a start
podwerkz
Posted: 06 Apr 2020 at 4:26pm |
It would be about as easy to look at the trailer to find all the screws as it would be to find and watch a youtube video about it, if one even existed.
And yeah, take a few samples to a good hardware store or big box home center...they will probably have what you need.
Jeepinator
Posted: 09 Apr 2020 at 9:14am |
You may need to be a member of the RPod Ownere group on Facebook to access this - https://www.facebook.com/groups/RPodOwners/permalink/10156315531555808/
It’s very detailed on replacing the screws
2018 Jeep Wrangler Willys
2017 179
Posted: 09 Apr 2020 at 10:03am |
It’s very detailed on replacing the screws |
Yup. Closed group. I can not in good conscience join FB.
Posted: 09 Apr 2020 at 10:20am |
+1 to Glue Guy.
tcj
Posted: 09 Apr 2020 at 10:44am |
Zukerberg will own your soul.
2018 R-pod 180 Hood River Edition
tcj
Posted: 09 Apr 2020 at 10:46am |
So is corrosion of screws in an Rpod a common issue?
Posted: 09 Apr 2020 at 11:25am |
+2 on the Slayer. Yup, that was Zuck’s nickname at his Hahvahd frat house.
Posted: 09 Apr 2020 at 12:42pm |
Rust is common to all screws made of steel when there is moisture available. I have had 2 FR trailers and they don't seem to be out of the ordinary, insofar as rust is concerned. If the screws are rusting where there should be no moisture, it's an early warning sign that water is getting into where it shouldn't. Parts of the screws that are exposed to the outside will normally show some rust if not powder coated or painted. If the shafts of the screws are rusting, you may want to try to figure out where the moisture is getting in and fix it. If it's coming in through the screw hole, then take the screw out, coat the threads with marine sealant caulk, and replace them. If it's coming in through some other source, then you'll need to track it down.
