Page 12> |
ricardos ![]() Newbie ![]() Joined: 26 Dec 2019 Location: Belgium Online Status: Offline Posts: 5 |
![]() Posted: 27 Dec 2019 at 7:04am |
I have same problems and did the same. Thank you too.
Rkmnoles ![]() Newbie ![]() Joined: 17 Apr 2019 Location: Jacksonville Fl Online Status: Offline Posts: 7 |
Great, thanks for the info.
06 Ford F-150 Lariat 4x4 Screw
Losing feels worse than winning feels good! |
Agree with "Google" the board. There are several sources for Dometic CBs on the web. Also some offer a repair service.
podrunner ![]() Senior Member ![]() ![]() Joined: 30 May 2013 Location: Draper, UT Online Status: Offline Posts: 106 |
Check amazon for the dinosaur brand replacement boards. I have not had to change mine, but I have seen this item discussed as a replacement. Good luck
2010 R Pod 151
2017 4runner 2006 Honda Metropolitan |
Pull the board and find the number stamped on it. Sometimes you get lucky and the actual manufacture is written there as well. Google that number and you should be able to find it (probably China) and order one.
Anyone know where to find a board?
I plugged the refrigerator into a separate outlet not on the trailer by way of extension cord and it does the same thing. You can’t turn it off or change any settings with the panel.
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6463 |
Try the simple thing first. Plug something else into the outlet behind the refrigerator (or use a multimeter) to verify that the outlet is getting power. Is the GFI outlet properly reset? Don't spend a ton of money until you rule out power problems.
Good luck on finding that circuit board at a realistic price, they are crazy expensive.
Doing the disconnect didn’t help. I will try and find a board.
Page 12> |
