  New Posts New Posts RSS Feed: Winterizing
Topic ClosedWinterizing
Jarhead View Drop Down
Direct Link To This Post Topic: Winterizing
    Posted: 08 Nov 2019 at 1:37pm
I switched the water pump to pull from the jug of antifreeze into the lines . Is it normal for the pump to stop? Does that mean the lines are full of antifreeze? There was still about half a gallon left in my second jug when it stopped?
texman View Drop Down
Direct Link To This Post Posted: 08 Nov 2019 at 2:01pm
do you have your sink and bathroom valves open while pump is on?
TexMan 2015 182g
2018 Sequoia
TexManMods
Direct Link To This Post Posted: 08 Nov 2019 at 2:05pm
If nothing is open or on, the pump when it reaches pressure will turn off automatically whether there is water or antifreeze in the lines.
Olddawgsrule View Drop Down
Direct Link To This Post Posted: 08 Nov 2019 at 2:13pm
Kinda curious how you changed the valves, if you're halfway into the second jug.. I was very quick on the trigger this time and filled all my lines with 1 gallon...
My first thought is you didn't shut off the hot water tank value and took that much to fill it before pressure built up.
Byways no Highways
2017 Tacoma
Truck Camper Build
2004 F150 My Overlander
Direct Link To This Post Posted: 08 Nov 2019 at 4:33pm
If he had the WH valves open it would have taken more than two jugs to fill.
Direct Link To This Post Posted: 08 Nov 2019 at 4:35pm
If empty... Thus the question.. Shall we wait to hear from the OP?
Byways no Highways
2017 Tacoma
Truck Camper Build
DavMar View Drop Down
Direct Link To This Post Posted: 09 Nov 2019 at 5:47pm
Why even bother using RV antifreeze unless you live in the frozen north country, except in the traps and a little in the toilet, and just use compressed air. I know its just to easy! Tongue
wonder dog.
2017 Rpod 180
2016 Toyota Tacoma SR5 4x4
Lexington, NC
Direct Link To This Post Posted: 10 Nov 2019 at 7:32am
I used to do that in my other trailers over the years. I found it to be a PITA compared to using anti-freeze. I can do the anti-freeze now with just a gallon and in less than a half hour (setup & clean-up).
To each their own.
Byways no Highways
2017 Tacoma
Truck Camper Build
riotkayak284 View Drop Down
Direct Link To This Post Posted: 10 Nov 2019 at 7:51am
Yep, Anitfreeze is super easy and takes little to no time.... and it adds a layer of insurance...
Direct Link To This Post Posted: 10 Nov 2019 at 12:54pm
I had the outside shower open so it used up extra antifreeze. Pain in the ass, Next time I’m just using air.
