  New Posts New Posts RSS Feed: LPG question
Topic ClosedLPG question
Direct Link To This Post Topic: LPG question
    Posted: 15 Oct 2019 at 3:27pm
We have some local places that supply Blue Rhino, and I've found those are often short of a full load. However, we also have numerous outlets that supply pre-filled tanks from Amerigas. Those seem to be filled most of the time; at least the ones we've checked.
However, most of the time, we just fill the tanks. Occasionally, we have one with a damaged shut-off valve or other issues, and we just exchange them. We use about 10 times the propane for our Weber grill than we do for the R-pod.
OldNeumanntapr View Drop Down
Direct Link To This Post Posted: 15 Oct 2019 at 4:42pm
I have heard that the standard practice is to only fill the 5 gallon tanks with 4 1/2 gallons. I don’t know if that’s because they need a margin of error when atmospheric pressure changes?
What’s the best thing to do with my in-line pressure gauge? Should I take it off? If it’s not really that accurate I don’t see the point in having it. Is it true that it can cause problems with gas flow.
Direct Link To This Post Posted: 15 Oct 2019 at 5:50pm
Filling propane tanks is somewhat temperature sensitive. The higher the temperature, the more the stuff expands. The gauge on our 500 gallon tank that we use for our house has a built-in de-rating to accommodate temperature expansion. In fact, it is posted to not fill over 80%.
podwerkz View Drop Down
Direct Link To This Post Posted: 15 Oct 2019 at 8:35pm
Blue Rhino fills LP tanks to 15 pounds. This is stated on the tank label and on the website.
RockyMtnRPod View Drop Down
Direct Link To This Post Posted: 15 Oct 2019 at 8:40pm
These work well too.  Might need a different size for a non-20lb tank.
https://www.amazon.com/PBKay-PG100-Propane-Gauge-Scale/dp/B011ACGEEW
low tech.
2020 TRD/Off Road Tundra with Sway Bar and SuperSprings
2016 178 "Sage"
twodues View Drop Down
Direct Link To This Post Posted: 16 Oct 2019 at 7:37am
Posted this a couple years back:
Check out these products: www.mopeka.com/products
Mine works extremely well and can be moved from one tank to another (magnetic attachment to bottom of cylinder).
