Page <123> |
Pod People
Joined: 22 Sep 2011 Location: Chapel Hill,NC Online Status: Offline Posts: 1091 |
Topic: Actual Weights as measuredPosted: 08 Oct 2019 at 8:04am |
I understand what Offgrid is saying. We have a 4x8 utility trailer that had a failure where the tongue met the body. It was a single 3x3 beam and not an A frame, so it had only a single point of connection. Welding a reinforcement beam under the original beam and adding triangle gussets took care of the issue. with the RPods A frame, at least there are 2 connection points. Vann
Posted: 08 Oct 2019 at 5:57am |
There is for sure more load being applied there by the wdh spring bars pulling down. Not to mention the dual batteries etc. Even without the wdh and batts, there is a high load stress location on the trailer frame a bit under the front of the box. Its not as high as the spot just behind the axle but it's there. So reinforcement in that general area isn't a bad idea. It would probably be better not to lose too much clearance at that point so a 2 inch tube might work better than a 4 inch one which would be the way I think I'd go in the axle area.
Posted: 08 Oct 2019 at 5:47am |
That's a good start, except that both TV axles are on the shoreline and we're trying to get more weight on the front axle and less on the rear because the rear one is on the edge of the cliff. Now, let's say the bridge contractor bought his bridge beams too short but still wants to use them so he puts a bolt through them and connects them at a center pivot point. Then to keep the whole thing from falling down he adds a spring between the two beams in the center holding them up. That's pretty close to what a wdh does.
Olddawgsrule
Joined: 20 Sep 2017 Location: New Hampshire Online Status: Offline Posts: 1014 |
Posted: 06 Oct 2019 at 3:32pm |
Still think there's magic involved! LOL I've come to a point of understanding the basic principles involved. Torque is something I get. The video and the way he does it, helped quite bit. To me it's how much force is being applied on on tongue frames to accomplish the feat (magic). The video is worth a watch and at one point he talks about what 'we' drive through and the added torque/force (?) that is applied. My questions are not if WDH (which he calls Load leveling and like that better) is good or bad.. It's what effect and how to compensate for. When my trailer comes back, I will re-enforce the tongue frame. I do believe there's more happening there then 'we' believe there is and worth the expense/effort. At least the conversation of.. I'm always open to learning. |
David and Danette
Joined: 24 Nov 2009 Online Status: Offline Posts: 1230 |
Posted: 06 Oct 2019 at 12:42pm |
The way the WDH was explained to me which made sense to me is that the WDH works like a bridge. The camper axle as one shoreline and the tow vehicle front axle being the other shoreline. The tongue weight is supported at the center of the bridge. Does that make sense.
2012 Vibe 6503 (2014-2019) 2009 r-pod 171 (2009-2014) 2023 Aliner Scout Lite Middle Tn |
Olddawgsrule
Posted: 06 Oct 2019 at 8:33am |
I watched yet another pretty good explanation of how WDH's work. To me there is still a bit of magic in this thing.. Even he states the weight on the ball remains, yet transfers/distributes the weight/torque. Magic I tell ya! It's gone, yet still there.. I like how he explains the action of torque the WDH does to compensate (?) the effect. So it's easier to understand why the weight remains, but the effect changes. Still say there's a bit of magic there.. Now he talked of the ball using most of this effect. I tend to wonder how much of this torque is also placed upon our hitch frame. Those of us that have, know how much pressure is on the WDH bars. For example only; if 200#'s are sent forward and 100#'s sent aft, then is the torque applied to the ball/tongue frame equal to that distribution? Or in order for the magic to happen, is it indeed greater.. Here's the video. He's informative and quite a kick to watch! http://www.youtube.com/watch?v=kCgRiVNaXFc
Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2742 |
Posted: 05 Oct 2019 at 7:58pm |
Also, air bags will not reduce the tongue weight. Air bags will increase the weight that your rear suspension can handle, but will not increase the weight the axle/bearings can handle or the weight the frame of the vehicle will handle.
Jeepinator
Joined: 08 Sep 2017 Location: Seacoast NH Online Status: Offline Posts: 72 |
Posted: 05 Oct 2019 at 6:50pm |
Given all the smart people on this thread, I’d like to add another element. What is the underlying risk of exceeding tongue weight and will air bags reduce it? I’ve not determined my exact tongue weight yet but I suspect I exceed the 350# even with the WDH.
I am aware that sway and receiver/coupler damage are potential risk factors but I assume there are others.
The TV and trailer are level when the WDH is engaged.
2018 Jeep Wrangler Willys
2017 179 |
Posted: 05 Oct 2019 at 5:05pm |
I’m right at the upper limit for tongue weight on my TV, so a wdh is for me pretty much essential. I’m looking forward to removing the dual lead acid batteries and placing a lithium battery further aft, thereby reducing tongue weight. After your frame issues, I’m also thinking about frame reinforcement as well. I think an rpod with a 2x4 tube in the axle area, plus a 5200 lb rated axle, and some additional frame reinforcement under the A frame extending from in front of the wdh attachment to a couple of feet aft of the front of the trailer box would make for a pretty robust boondocking trailer at a relatively low cost. The area around the wdh attachment and the front of the box also theoretically gets some high frame loads.
Olddawgsrule
Posted: 05 Oct 2019 at 3:22pm |
I understand what your saying. The whole idea and physic's about weight distribution is still something I'm learning about and wether or not it's better than re-enforcing your TV is better, if your TV is capable. For some, there's no choice. For some, even WDH will not work. I jumped pretty quick due to costs and not understanding. I wanted sway control and cost of a WDH with sway made sense at the time. I'm debating that decision now. |
Page <123> |
