  New Posts New Posts RSS Feed: Missing table
Topic ClosedMissing table
Pod People View Drop Down
Direct Link To This Post Topic: Missing table
    Posted: 29 Aug 2019 at 9:04am
We had the same bulky, terrible table in our 179. I built a new table with double pedestals from 3/4" birch plywood top and also a plywood base.  It travels on the bed after taking the pedestals apart.  I made it larger than we wanted originally and have gradually cut it down to the size that we want(24x39). It is very stable and much lighter than the original.
Vann
Vann & Laura 2015 RPod 179
Daniel View Drop Down
Direct Link To This Post Posted: 29 Aug 2019 at 7:25am
OK thanks for the info. I'll probably work on making my own table and a different type of Base. I'm pretty tall and I was also wondering about legroom.
Happy Tripping View Drop Down
Direct Link To This Post Posted: 28 Aug 2019 at 5:27pm
I sorta like our table. Keep it out of the rain tho or you'll need a new top.
Internet search results from 2010 - It probably isn't current but gets you started.
Scott,
Yes, the new table base is available for your purchase.  I do believe you can use your current table top.  The base is $85.50 plus shipping.  You may order through my parts administrator Brandie Lamb at 574-642-3119 Ext 209.  We accept Visa or Master Card.
Sincerely,
Susan Thornberg
Warranty, Parts & Service Manager
podwerkz View Drop Down
Direct Link To This Post Posted: 28 Aug 2019 at 5:22pm
Yeah the original folding table is heavy...really heavy. It will pinch your fingers badly if you actually try to fold it. And the legs were always in the way when you made an attempt to sit near it... AND on top of all that, the straps that came with it were intended for tying it down during travel...what a pain.
You are much better off to buy a standard pedestal base and buy or make a suitable table top surface.
john in idaho View Drop Down
Direct Link To This Post Posted: 28 Aug 2019 at 4:40pm
You are not missing much.  I have the foldup table that came with our 2015 179 in the green house as a plant stand.It was always in the way, heavy, and hard to sit at.  I made another one we like a whole lot better.  3/4" plywood 2 ft square for the base, a boat store pedestal socket ,  pedestal and a similar socket mounted on a 3/4" ply on the underside of the plywood top, which is about 6 or so inches bigger than the bottom.  It rides on the bed all apart.  If you live close to Idaho you could get this one out of the greenhouse.  Hardly used.
Direct Link To This Post Posted: 28 Aug 2019 at 3:59pm
Hello everybody my name is Dan I'm fairly new to the Forum. Just purchased a 2017 r-pod 178. The previous owner had modified the dinette table area. They put in a futon type bed. I have all the original cushions with no table. I'm simply trying to put it back to its original configuration. I'm not even sure if I can buy a new table for this camper. Any ideas would be helpful thank you so much
