  New Posts New Posts RSS Feed: Floor failure!!!
Topic ClosedFloor failure!!!
 Post Reply Post Reply Page  <1 34567 13>
Direct Link To This Post Topic: Floor failure!!!
    Posted: 12 Aug 2019 at 4:01pm
Never saw that anywhere.
Olddawgsrule View Drop Down
Direct Link To This Post Posted: 12 Aug 2019 at 4:09pm
Trailer just left on the flatbed truck. Part two of the story begins!
With it up in the air and easy to sight, I see the axle middle section, mount to mount as really good. Much greater than the 1/8" I measured, but I went end to end.
Outboard on the slide side is definitely bent upward. I can see the bend. That's where it happened, slide side.
As I thought I saw, both beams are bent.
The guy picking it up admitted it's his first trailer.. No kidding dude, I saw it in your eyes. There are times you hope for the Pro's to be smarter than you. Not in this case. Thankfully I was there..
Lippert will most probably stand behind their axle, but really doubting how much FR will stand behind. Guess it's all on the Dealership and what they can do for me.
Saddened beyond sayin'..
Byways no Highways
2017 Tacoma
Truck Camper Build
2004 F150 My Overlander
Direct Link To This Post Posted: 12 Aug 2019 at 5:01pm
This has always been a rumor for me, due never asking.. So I shall!
It's rumored that the HRE's have a 5200# axle. If true, are their frame's also of thicker steel?
I met a HRE owner that claimed his axle was a 5200#...
No.
Direct Link To This Post Posted: 13 Aug 2019 at 3:47am
With all that said.. Wouldn't braking spread that force over both sides? Wouldn't then the torsion be working in my favor? Now 'I'm' learning enough to be dangerous.. or confusing the crap out of myself..
Yes, braking would act to apply a moment (torque) to the axle and frame on both sides. How much depends on how aggressively you're braking, how much weight is on your trailer wheels, how good your brakes are, and the coefficient of friction between the tires and the road. Typical dry pavement friction coefficient for street tires is about 0.7 just before lockup so theoretically you could get 3500 lb x 0.7/2 = 1225 lbs force at the contract patch on each side. With about a 14 inch moment arm (because I have a lift kit) that's 17150 in-lb, compared to about 12250 in-lb for the moment from the torsion axle at 1g.  In practice I can't lock up my trailer brakes (new and properly burned in) on dry pavement even with my brake controller on full boost so its going to be less than that.
In any case, its pretty easy to see how the combination of some braking plus the vertical force on the frame from hitting a bump, plus the torque from the torsion axle from hitting its stop could combine to bend or break the frame at that spot. In future when I brake for a bump or pothole I'm going to try to be careful to release the brakes before the trailer actually rolls over the bump.
No, the torque applied to the frame from the torsion axle and the brakes is in the same direction of rotation (counterclockwise when looking at the slide side).
Direct Link To This Post Posted: 13 Aug 2019 at 9:05am
Trailer went to the Dealership yesterday afternoon. I just heard from the Dealership that it's going in today for inspection. Statement was shortly..
I may have an indication of where this is going later today.
Send some good JUJU may way please!
Byways no Highways
2017 Tacoma
Truck Camper Build
Direct Link To This Post Posted: 13 Aug 2019 at 10:04am
Sent!
Direct Link To This Post Posted: 13 Aug 2019 at 2:48pm
My guess is they will straighten the frame, and reinforce it with a flat panel scab. That's what I would do.
Direct Link To This Post Posted: 13 Aug 2019 at 3:54pm
First statement was, they'd be asking for a new frame. That was a couple days ago before they had it and going by my pictures.
If it comes back here, un-repaired, be ready for a thread of removing the box and upgrading the frame.
I did start a thread asking if anyone has removed/separated the body from the frame. Hoping someone has..
Byways no Highways
2017 Tacoma
Truck Camper Build
Direct Link To This Post Posted: 13 Aug 2019 at 7:32pm
[/QUOTE
I was told by a RV dealer that the electric brakes were designed to not lock up.
2023 Aliner Scout Lite
Direct Link To This Post Posted: 14 Aug 2019 at 3:17am
The way it is supposed to work for max emergency braking is that you set up your brake controller so that at its maximum adjusted output voltage (when the manual slide is fully on) the braking force is just short of lockup on dry pavement. That is the setup procedure the controller manufacturers recommend because that will give you the shortest stops. If you set the controller voltage higher and apply full brakes you will  lock up the wheels which will cause the braking force to go down because you're now skidding along on a patch of melting rubber so the friction coefficient is reduced. If you set the voltage lower then you are not going to get all the possible braking action if you ever need it.
On many travel trailers, my rPod being one, you can't get enough braking action to lock up the wheels even at full voltage from the brake controller. The brakes just aren't powerful enough. Since I can't get there I have no idea how much more emergency stopping power my tires could give me before I start to skid.  If a trailer salesperson wants to call that a design "feature" ok I guess, but to me its a design weakness.   I'd prefer to have more brake capacity available and be able to adjust them with my brake controller to the level I want.
