List Your Mods:
 Post Reply Post Reply Page  <1 910111213 78>
Kahonu37 View Drop Down
Post Options Post Options   Quote Kahonu37 Quote  Post ReplyReply Direct Link To This Post Topic: List Your Mods:
    Posted: 21 Nov 2019 at 3:37pm
Boater
Since the installation of the riser kit, have you notice any differences in towing, gas mileage, or wind drag?
We are looking to also increase our clearance, just doing the research after watching a couple of videos.
Do the Hood Rivers use a riser or are they built in?
2018 179
2012 NISSAN XTERRA (retired 12/19)
2019 RAM 1500 WARLOCK (new)
A.R.E. V Series Topper
WDH Equalizer 600/6000
Carolyn View Drop Down
Post Options Post Options   Quote Carolyn Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2019 at 2:22pm
It has been a while, but what do you mean that you Installed the tracks "... with #4 screws OUTSIDE the slide slots …" Did you drill new holes?
Carolyn
Frogpod2012 View Drop Down
Post Options Post Options   Quote Frogpod2012 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2019 at 12:03am
Xtra storage.
ANOTHER ADVENTURE
Motor7 View Drop Down
Post Options Post Options   Quote Motor7 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2019 at 4:17pm
Originally posted by boater
Hi , Boater here , we just completed installing the Forest River supplied 4 inch Lippert Axle raise kit on our 2018 178 . Unit has 15 inch tires and Lipppert torsion axle .  Just love the lift kit results  ,, good clearance , and do not feel we need new step unit. ( have single step) . Of course had to have the sway control / hitch system we use re done to facilitate the raised height . Also I will add 4 inches of blocks/ pads under the 4 trailer stabilizer jacks just so they do not go down so far .  After the initial kit  cost from Forest River , the  install was $250. re do sway bars $65 . Plan ahead however to find a dealer or service company to install the lift kit . Many are not familiar and will not do it . Took 2 weeks to get the kit from Forest River and they were extremely helpful .
We not feel we are ready for National forest campgrounds , boondocking and any gully’s for surprises that come our way .
In my opinion, all of the Pods should come with risers....best mod so far for us has been #1 - risers, #2 Solar, #3 - 6" Queen mattress.
2016 R-Pod 176T
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2019 at 9:43am
Originally posted by lms1958
I looked at the Amazon link for the
Grill Igniter with Spark Plug Wire
and it says that it requires a AA battery.  Where is the part of the igniter that has the battery, and do you have to take the stove apart to replace the battery?
No, at least on the one we have. You unscrew the ring around the push button, and the battery is held in there.
lms1958 View Drop Down
Post Options Post Options   Quote lms1958 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2019 at 1:42am
2018 Hood River 189
2012 Toyota 4 Runner
boater View Drop Down
Post Options Post Options   Quote boater Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2019 at 11:17am
mhfnet View Drop Down
Post Options Post Options   Quote mhfnet Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2019 at 9:11am
I made a couple mods to my 179 I thought I'd share:
- I added an electronic igniter for the stove top burners. Only $12 and fairly easy to do.  Drill holes for the igniters and mount the push button on the cabinet panel. The most difficult was to position the igniter rods far enough away from arching to the burner then bend in the rod at the end right to the point gas exits the burner. No more needing to use a butane lighter!
- To significantly reduce drafts to make sleeping more comfortable and improve energy efficiency, I also caulked around the bed platform with clear caulk, put foam weather stripping under the strips supporting the plywood, and added screws in the corners and mid-way of the plywood (6 screws vs only 2 from the factory) to improve the seal of the plywood to the weatherstripping. Total cost about $10.
- My Apple iPhone 8 makes a great video player as it has 256 GB of memory and I can download shows/movies from Netflix and Amazon Prime to watch on the Rpod TV with HDMI input. To do this you need the Apple lightning to HDMI adapter (only one that works with protected content). You also need a 12V DC to AC converter to power the TV when only on battery and install a 12V cigarette lighter socket to power the converter, which I installed up by the TV spliced into the entertainment system 12V power to power it. I also put a combo USB port/12V socket by the bed so I can charge my iPhone and 12V vacuum I also carry. It is mounted on the bed platform next the AC outlet and spliced it into the 12V used for the furnace.
Here are a list of the items.
- I also added a wireless back-up camera I posted in this forum at the link below.
Ben Herman View Drop Down
Post Options Post Options   Quote Ben Herman Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2019 at 12:27pm
I built a shelf that goes across the bed on my 179 - the walls are really not strong at all, you can only use extra-short molly bolts as the veneer skin is very thin. I built mine out of 1/8" underlayment plywood and 1/2" milled hemlock (Lowes carries it) which is strong and very lightweight. I wouldn't plan on anything that weighs more than 20-25 lbs loaded. We use ours for clothes in plastic baskets.
Post Options Post Options   Quote offgrid Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2019 at 11:15am
Take a look at this construction video:
The flat section of the roof and the walls are framed with 1 inch square AL tubing. The curved roof sections contain wood stringers. I wouldn't recommend trying to attach anything significant to those, there's not much strength there.
If you have a cool humid morning you can often see where the structural members are are because of condensation differences.
