  New Posts New Posts RSS Feed: Replacement axle?
Topic ClosedReplacement axle?
 Post Reply Post Reply Page  <1 8910
Direct Link To This Post Topic: Replacement axle?
    Posted: 13 May 2019 at 4:16pm
Originally posted by dcholden
I do not see any posts about using leaf springs and axle to replace the torsion axle.  Is there any reason why leaf springs and new a axle would not work to replace the torsion axle? We live full time in Baja Calif.,Mexico and most of our use is on very bad roads.
One of our members has suggested that but no one has tried it yet as far as I know. The only reason it wouldn't work that I can think of is that you might end up with a higher ride height than you would like. You would still have the same issue with a large overhang between the wheels and the trailer frame so a higher rated axle would probably be needed.
Direct Link To This Post Posted: 13 May 2019 at 4:27pm
I also think you would have to put a doubler of some sort at the four points where the leaf springs attach to the frame.
Direct Link To This Post Posted: 13 May 2019 at 4:30pm
+1
texman View Drop Down
Direct Link To This Post Posted: 20 May 2019 at 10:06am
it looks bent to me.  also, i just hauled the pod to put up for a while and no trailer brakes.  my brake controller works fine on a flatbed trailer with a bargman connecter, so i dont think it is the controller.  I just reread this whole thread and i am still not sure what Stephen H ended up doing, replace or no? Anyway i guess i am starting down this axle replacement routine.  Please give me some guidance.  I think it is a Dexter axle.
TexMan 2015 182g
2018 Sequoia
TexManMods
Direct Link To This Post Posted: 20 May 2019 at 10:22am
Sorry to hear you're having problems. There should be a sticker on the axle which will tell you who made it and what the rating is. If its a Dexter, is the tube flat or turned as a diamond? Can you get the tube dimensions and thickness?
The other thing to do is to see if its crowned (cambered) or not. Run a string line along the bottom and measure the gap in the center if there is one.
Re the brakes, if both sides are out its most likely the wiring. If you've convinced yourself that its not a problem in the trailer connector itself, check the wiring to the magnets next.  The crummy insulation displacement connectors FR uses are pretty notorious for coming undone. You can also check for voltage at the brake magnet connections with your brake controller connected and energized (by taping the manual lever on or having a helper hold in on).
good luck!
Direct Link To This Post Posted: 20 May 2019 at 1:49pm
The tires on mine were wearing with significant wear on the inside shoulders of the tires. The wheels and tires were definitely splayed out. The dealer where I purchased it did the axle replacement along with brake and bearing replacement. The door side had leaked grease and although I had cleaned it up, the magnet showed signs of excessive wear also so the whole brake assemblies were replaced and a new hub was installed on the door side. The slide side hub was okay. Along with the axle repair, a leak in the slide-out was repaired. The whole job cost me about $3,000.  Given how many miles I have been in the pod, it probably worked out to about ten cents a mile.
