  New Posts New Posts RSS Feed: CPAP
Topic ClosedCPAP
EchoGale View Drop Down
Direct Link To This Post Topic: CPAP
    Posted: 30 Apr 2019 at 1:41pm
G'Afternoon all,
I'm still messing with strategies for my traveling companion's CPAP.
We're taking the pod in tomorrow to have bearings repacked, brakes and tires checked and were going to have a DC socket installed because we have a power cord for the CPAP that plugs into the device on one end and a CPAP battery on the other with a DC socket.  (Before you ask the external CPAP battery won't last long enough to be more than a backup option).  The CPAP battery does work but the DC plug won't run the CPAP in either of our cars.
Any thought on why this would be? Is it because this particular CPAP might need an inverter and the battery supplies one?  If it won't work in the car it won't work with a DC outlet installed in the camper either, will it?
While we're at it, is there anything else we should have looked at while we're at the RV shop?  This will be our first visit there and while the 2016 pod is in great shape we don't know what's ever been done (we have been maintaining the batteries).
I'll appreciate your opinions.
Julie
Direct Link To This Post Posted: 30 Apr 2019 at 2:21pm
The only thing I can think of off the top of my head (forgive me if I'm stating the obvious) is did you have the car ignition on when you tested the cpap? If you share the brand and model cpap we could look it up and see if the that might tell us anything.
If you don't have any leak problems and all your appliances and fixtures work as they should (check both gas end electric operation before you go in) then I can't think of anything else you might want to have the RV place check for you.
wooleeman View Drop Down
Direct Link To This Post Posted: 30 Apr 2019 at 2:35pm
If the DC plug is for the cigarette lighter outlet (I know I'm old school) then is the fuse blown inside the connector plug? The tip of the plug should unscrew and there would be a glass inline fuse inside.
2022 RP-202
2016 RP-179 (Sold 9/2020)
2014 Silverado Crew Cab. 6-1/2' Bed
Golden Retriever (DOB 6/16/2020)
English Bulldog (RIP 6/15/2020)
Direct Link To This Post Posted: 30 Apr 2019 at 2:41pm
Echo, another possible problem is if you had the motor running, you could have created enough line noise for your CPAP that it wouldn't run.  I saw this happen to one where I fixed the reversed polarity of the plug and it ran fine, but when my friend tried to run it with the generator to his RV going, the CPAP refused to run until he turned off the generator.  .... and returned us camping near him to blissful peace and quiet.  Clap
Direct Link To This Post Posted: 30 Apr 2019 at 3:33pm
Thanks so much...the car was tried both running and not running but I will look for a fuse.  :)
Julie
TheBum View Drop Down
Direct Link To This Post Posted: 30 Apr 2019 at 3:34pm
Was the DC cord designed for the CPAP? If not, it may have the wrong polarity in the connector, which I assume is a typical DC barrel connector. Another possibility with an aftermarket cord is that the CPAP runs on 24V and the straight DC cord isn't providing enough voltage, i.e. it needs a voltage step-up circuit.
Alan
2022 R-Pod 196 "RaptoRPod"
2022 Ram 1500 Lone Star 4x4
Three cats
Direct Link To This Post Posted: 30 Apr 2019 at 7:49pm
It would help if you mention the brand and model of the CPAP machine. Mine is a Respironics System One. I purchased the 12V power cord made for this model. It was much more expensive than a generic 12V cord but it works fine plugged into the 12V outlets I installed. One way to make sure you know the power requirements of your CPAP machine is to look at the transformer block. Look at the output voltage. Is it 12V or 24V?
Direct Link To This Post Posted: 30 Apr 2019 at 7:59pm
Thanks Stephen, Its a Resmed Airsense 10 but I don't have (or have access to the other information).  I've read that some need inverters and others either already have them or don't need them.  I suspect this is the problem and I think what we'll try next.  :)
I think its not a fuse because it can work on the cpap battery but not on either car. We also have this weird cord that has a 12 volt socket on one end and little clips like jumper cables on the other.  I think that can connect directly to one of the camper batteries but we'd have to slam the door on the cord.
how fun is all this?LOL
Julie
Direct Link To This Post Posted: 30 Apr 2019 at 8:13pm
Okay, I did a real quick web search. Your Resmed Airsense 10 runs on 24V. https://www.resmed.com/uk/en/consumer/products/accessories/air-10-dc-dc-converter.html
You would need to get a 12V to 24V converter. You could check Amazon for this item.
Direct Link To This Post Posted: 01 May 2019 at 5:22am
