Page 123 4> |
| Author | ||
Topic: Generator RecommendationsPosted: 22 Apr 2019 at 6:59am |
Here's the specs for the 13.5 Dometic Brisk Air II:
Coincidentally that shows a power consumption of 1670 watts. In the US a/c's EER (energy efficiency ratio = BTU/hour divided by watts load) and power consumption are typically spec'd at 95F 40% relative humidity outdoors and 80F 51% RH indoors. I was pretty close to that when I took my measurements last summer. We know that the SEER (seasonal) efficiency ratings of a/c's are much better than the EER's which implies that they are a lot more efficient when its cooler outside. Here is a link discussing this Even it you find that you're pulling the 1700 running watts when it gets hot I don't think your 3500 watt genny will have any problems starting the a/c unless you're trying to run the microwave or some other big ac load at the same time. Folks seem to usually have trouble starting the a/c (without an easystart) with gennies rated at 3kW or lower. |
Posted: 22 Apr 2019 at 6:16am |
Yes, that is indeed curious. The 1762 watts is pretty close to the 1670 I get using my clamp on ammeter measurement and your power factor measurement. Do you have a clamp on ammeter you can compare to the current reading on the kill-a-watt? |
Posted: 22 Apr 2019 at 6:13am |
No, it won't. RMS stands for root mean square, which is a fancy way of "averaging" the current or voltage beining measured. That doesn't tell you anything about how far out of phase with each other the current and voltage cycles are, so you don't know what the true power being used is. The kill-a-watt is a pretty low cost way to do it, but those are limited to 15A. You might try one of these: |
marwayne
Posted: 21 Apr 2019 at 11:39pm |
When I ran my AC with my 2000i Honda, I only ran it on low but I turned on the fan first let it run for about 5 min to cool the unit then I kicked in the compressor After a very short time the AC dropped down to 1480 watts.
podwerkz
Posted: 21 Apr 2019 at 10:09pm |
It's a 2019, with a standard 13.5 Dometic roof air. There was no manual for the roof A/C unit in my paperwork, but I think I found it on the Dometic webpage, and it seems to show 1762 running watts. Hmmm....maybe the lower line voltage meant less wattage, duh, or maybe I need to do another test with a higher heat load. Or maybe the kill-a-watt meter is off by a few hundred watts. Things get curiouser and curiouser.... |
Posted: 21 Apr 2019 at 8:24pm |
If one has a clamp-on meter that claims to be able to measure true RMS current, would it measure accurate pwer used for AC loads?
Posted: 21 Apr 2019 at 8:09pm |
Just for the sake of being thorough, it’s also possible that my 2015 vintage Dometic roof air isn’t as efficient as the unit in your rpod. What year is yours? |
Posted: 21 Apr 2019 at 8:04pm |
In the dc (direct current) world power used (watts) = volts x amps. In the ac (alternating current) world it’s not that simple, because both voltage and current are constantly changing. If the current is not changing in phase with the voltage then the power used is less than the volts x amps. The ratio of power divided by volts x amps is the power factor. Typically in motor loads like your a/c compressor the current lags behind the voltage so the power factor is less than 1. In resistor loads like your water heater element the current and voltage are in phase and the pf is very close to 1.
It’s useful to know what the power factor of a load is for a couple of reasons. One is that you can’t just use your clamp on current meter to measure power used in ac loads. The other is that if you’re running a load with a low power factor on a generator you could overload the generator electrical circuit and trip it’s breaker while still having plenty of power available from the engine itself. At a pf of .95 the roof ac is pretty good for an a/c compressor so you could expect that the genny electrical circuit and engine will be pretty well balanced and one won’t give up much before the other. |
podwerkz
Posted: 21 Apr 2019 at 7:55pm |
That last part is good to know, I will check on that at a later time. My 3500/4000 watt genset, so far, has run the AC but I have not tested it for a long period in hot weather, nor at high altitude where power output tends to drop. Still, I have confidence in it.
Posted: 21 Apr 2019 at 7:41pm |
No, nothing else was turned on, I was doing a detailed energy audit, measuring each load one at a time. It’s typical for a/c compressor loading to vary significantly with temperature differential between the evaporator and condenser. That’s why folks can find that a low power generator will start and run their a/c units initially but not after a second or third cycle.
Page 123 4> |
