Page 123> |
| Author | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Topic: TiresPosted: 21 Jan 2019 at 10:04am |
+2 on the LRD Carlisle 14" which I also have. When I had the LRC tires on, I had someone try to tell me my tires were going flat because of the sidewall flex. They were at the proper pressure. The LRD tires do much better and I don't worry as much about one popping and ripping off a fender.
Posted: 21 Jan 2019 at 9:51am |
+1, same positive comments.
Posted: 21 Jan 2019 at 9:40am |
We run Carlyle 205/14 LRD's, replacing LRC's, and have been real happy with them. It gives a smoother ride from the TV perspective. The trailer seems to track better and the TV seems to work a little less hard. I haven't compared the mileage but it is likely a tad bit better due to the reduced rolling resistance.
Posted: 21 Jan 2019 at 6:38am |
It all depends on what your objective is.
For Carlisle, the load ratings are:
I'd expect other brands to be similar. You also need to consider the wheel load ratings, a system is only as good as its weakest link. IIRC, the OE 14 inch wheels are only rated for 1750 lbs. In my case (heavy rPod 179) I wanted my tire and wheel load ratings as high as possible without getting into LRE which I've heard concerns about being too stiff and causing excessive trailer vibration. So I bought premounted 15 inch tires and wheels in LRD which gives 2540 lbs for both. $161 each. With what I have to pay here on the OBX to mount tires I almost got the new wheels for free. |
Posted: 20 Jan 2019 at 7:05pm |
The max you will get with most ST tires is D in 14 inch. 15s E is available. I know I went to D over the supplied Cs and it had a noticeable improvement. I never considered a 15" tire and rim, there is a point where the gain is not affordable or reasonable.
michaeln
Joined: 08 Dec 2018 Location: Avery, CA Online Status: Offline Posts: 40 |
Posted: 20 Jan 2019 at 6:59pm |
The ST225/75R15s I have are load range E. I believe the 14" version is load range D.
Avery, CA |
David and Danette
Joined: 24 Nov 2009 Online Status: Offline Posts: 1227 |
On our Vibe we have new Goodyear Endurance tires 225/75/R15 trailer tires load range D 80 psi.
Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2735 |
Posted: 20 Jan 2019 at 6:52pm |
That would be another advantage of the load range D tire; the higher operating pressure. Load range C only goes to 50 PSI, and that means more sidewall deflection regardless of the load rating.
michaeln
Posted: 20 Jan 2019 at 6:47pm |
I think the stiffer sidewalls of the LRE Goodyear Endurance compared to the stock soft junky HRE tires might actually result in MORE ride height, especially if they are aired up to 70-80psi.
Avery, CA |
Wood River Pod
Joined: 30 Sep 2016 Location: Wood River, ID Online Status: Offline Posts: 153 |
Posted: 20 Jan 2019 at 4:35pm |
Glue guy, thanks for your math. I thought I would sacrifice more clearance going to the 225's. Based on your calc, I'd lose less than an inch. Good to know. Thanks I once scoured the internet and found a Westlake dealer in Canada that sold the exact replacement for the stock HR tires...but I wanted to find a replacement with a higher load rating, not the exact replacement. Oh well. Sounds like when I want the Westlakes gone, I'll move down to the 225's. Thanks
Page 123> |
