  New Posts New Posts RSS Feed: Installation of rear camera
Topic ClosedInstallation of rear camera - Event Date: 24 Jun 2017
 Post Reply Post Reply Page  <12345 6>
DavMar View Drop Down
Direct Link To This Post Calendar Event: Installation of rear camera
    Posted: 19 Mar 2019 at 6:51pm
Originally posted by Kahonu37
Thanks, appreciate the quick response. Emailed the camera company an they said the LED light will interfere with the wireless transmission. So my game plan is to remove the center LED light an use its hole to tap into the wires and reseal it. Therefore no holes in the roof and it is centered. My spoiler is sealed all the way around.
Sorry to say but what this camera company has told you I have to throw the B.S. flag on their information! There is no way a LED light will interfere with the transmission from your camera WiFi transmitter (or what ever means of transmitting RF signal carrying composite video ). Why you may ask, well simply because an LED is a light emitting diode and does not put out any RF signal that can interfere. It may interfere if you set an LED light in front of your camera because of to much light.
Your idea on the mount sounds very doable, good luck! Smile
wonder dog.
2017 Rpod 180
2016 Toyota Tacoma SR5 4x4
Lexington, NC
Kahonu37 View Drop Down
Direct Link To This Post Posted: 19 Mar 2019 at 2:25pm
2018 179
2012 NISSAN XTERRA (retired 12/19)
2019 RAM 1500 WARLOCK (new)
A.R.E. V Series Topper
WDH Equalizer 600/6000
ribet View Drop Down
Direct Link To This Post Posted: 18 Mar 2019 at 10:45pm
I have installed at least 10 Peaks and have not had any problems.  Installed on campers, trailers, pickups and one VW van camper.  Installed using the license plate bracket and sometimes had to turn the camera upside down.  Wired many to the license plate light so driver could see anytime he turned on the parking light and some wired to the back up light to work as normal.  Purchased all from local Napa Auto Parts store due to good warranty.  Even installed on on my Harley Sportster so I could see what was behind me with no handle bar vibration in the mirror.  Mounted screen on windshield.  Too much information.
voisj View Drop Down
Direct Link To This Post Posted: 17 Mar 2019 at 6:24pm
Kahona,
If you remove just the bottom screws on the spoiler you can lift it and gain access without having to redo the sealant on top. the bottom isn't sealed so water can get out. The only wires in there are for those lights. Yes white is ground,(but test anyways).
rgds John
SLOPODMODS
John&Sue,SLO,CA
Direct Link To This Post Posted: 17 Mar 2019 at 7:15am
Originally posted by GlueGuy
Do you remember how you identified which wires to use?
I think there are only two wires under the spoiler: power and groun.
I assume black is positive and white is ground?
[/QUOTE
That would be correct per the national electric code, but its always safest to verify first with a voltmeter.
Direct Link To This Post Posted: 17 Mar 2019 at 3:01am
Do you remember how you identified which wires to use?[/QUOTE
2018 179
Direct Link To This Post Posted: 22 Nov 2018 at 6:33pm
Hey John,
Every year my local RV guy has a garage sale and I got this bumper for $35,had to buy it!so when I installed it I rigged it so it would either sit in flush to the body or it would slide out of the frame rails about 20in. I figured I would use it for a cargo rack,but the real reason I put it on with so I could get the scissor Jack's higher off the ground so they wouldn't hit anymore. It also doubles as a sewer line holder. Worked perfect and I'm kind of a dork, I sometimes back into things so it served its purpose. There's a few more pictures in my slopodmods Link below.
cheers John
SLOPODMODS
John&Sue,SLO,CA
john in idaho View Drop Down
Direct Link To This Post Posted: 22 Nov 2018 at 10:55am
Good looking rear bumper.  What is the story?
Direct Link To This Post Posted: 21 Nov 2018 at 11:05am
Originally posted by VermontPodder
I did see an example of one owner (sorry I forgot who it was) who fabricated a mount on a post using the rear receiver and intially thought that would work. I found my running lights are routed inside the camper and not underneath - so I would have to run 12v out to power the camera.There is no wires underneath I could use on the new 179.
Thanks
VP, Just noticed you referenced my backup camera, Here's a photo and and how i wired it.
after making the mount I ran 1 three wire (black,white ,green) encased cord (home depot $11)
Ran the wire down the slideout side frame rail.
Under the front corner of the pod where the trailer whip(wire that plugs int the tow vehicle) connects to the pod, There was a blue wire coming out of the whip side that had a cap on it, this wire was controlled(made hot 12v) by putting the truck in reverse.
There is a good ground and also good 12v that you can use under here
I put a 4pin trailer connector on the end next to the trailer hitch.
and wired up my camera on the mount, with a floodlight, with the other end 4pin trailer connector so it could be removed if necessary.
I ended up a switch on the flood light and wiring it with straight 12v,, because then it could be used whenever and the flood light was too much for the camera to work properly.
The camera is now mounted in the spoiler and powered by the spoiler lights. Which is easy and out of the way, and leaves room for other stuff on the back.
ds John
SLOPODMODS
John&Sue,SLO,CA
Direct Link To This Post Posted: 21 Nov 2018 at 10:15am
crw8sr, oh my I'm doomed no camera for me! Cry
wonder dog.
2017 Rpod 180
Lexington, NC
