Page <123 |
Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3395 |
Calendar Event: New tow vehicle questionsPosted: 02 Nov 2018 at 8:36pm |
Offgrid, good point, weigh your tongue weight. My son has an '18 F-250 with a 10" lift, nearly need a stepladder to get in the cab but it has a scale on the hitch to read hitch weight, pretty neat as I never saw one of those things before. Wanted to see how accurate it was so we weighed it on a Sherline Scale and then transferred our 177 to his truck and got the exact same reading 350 lbs. Originally I was going to take his receiver off and put it on my Explorer but noticed that the receiver on his truck is 2.5 inches, my Explorer is the normal 2".
Posted: 02 Nov 2018 at 9:32pm |
Never seen a hitch scale, sounds cool. If you want to know your hitch weight and don't have a Sherline or an F250 with a hitch scale and you don't want to mess around with the bathroom scale teeter totter method, there is an easy way if you have access to a commercial scale. Drive your tow vehicle over the scale, get the weight. Go get your trailer, (leave the wdh untensioned) and tow it to the scale. Roll the TV on the scale leaving the trailer axle off and get the weight. The difference is your tongue weight. I use the scale down at our county waste transfer station. Accurate to 10 lbs each measurement so the difference is accurate to 20 lbs.
voisj
Joined: 19 Jul 2016 Location: San Luis Obispo Online Status: Offline Posts: 471 |
Posted: 02 Nov 2018 at 11:56pm |
Here's the one I got it's pretty accurate
scale ball |
Posted: 03 Nov 2018 at 6:49am |
Thanks, looks like a great ad on, cheaper than a Sherline and always available. I'll have to measure my wdh and see if it fits in the available space.
Posted: 03 Nov 2018 at 7:51am |
The one my son has is a Weigh Safe model WS8 2.5 and has an application of 14,500 lbs. max GTW and 2,200 lbs. max tongue weight, more than sufficient for any r-pod, even if overloaded. Price is # 299.00 and is available for 2", 2.5", and 3" receivers.
Posted: 03 Nov 2018 at 10:23am |
Even the 10K lbs one is enough for two rpods... My issue is I have a Reese Pro wdh which has its trunnion bar engagement under the ball so it would be a tight fit. I like it though, thanks guys.
crankster78
Joined: 08 May 2018 Location: Minn Online Status: Offline Posts: 163 |
Posted: 04 Nov 2018 at 10:25am |
Greetings I have a 2007 F-159 8 foot bed, standard cab. My 179 has dual tanks and a single group 27 battery. I did remove the truck spare tire and put it in the front of the box. I've towed at least 15000 miles and have never had a sway problem. I have 120000 miles on the truck and put on HD shocks with helper springs. I get about 2 to 2 1/2 inches of drop when I hook up the 179 with full fresh water. I'm not opposed to sway bars, but my truck has a 144 inch wheelbase. Which makes a difference. Just my experience. Crankster78 MN
Crankster 78 R-179 2015
Posted: 04 Nov 2018 at 2:25pm |
Totally agree with you crankster. My 1994 F-150 4x4 is similar: 8 foot bed and standard cab with the same 144" wheelbase (but I got you beat on mileage at 320,000 miles and hopefully on deer kills - 31, and deer 'hits'- - - too many to count). No issues towing encountering sway. I will admit you probably carry more weight on your truck, as mine has been on a 'weight loss' program for the last 8 years due to severe rust. Our 2011 F-150 4x4 is a supercab and a 6.5 foot bed, again, no sway ever encountered. Same goes for our 2013 Explorer 2WD. BUT on our 2008 Explorer 4x4 we could never get above 40 mph without severe trailer sway. In fact on our maiden voyage going on our first camp out we turned around after 15 miles and brought it home, too much sway, nearly lost control of it at 40 mph, bummer for us, but after getting home purchased an anti-sway bar link and never had a problem again. In summation, to agree with you, length of wheelbase plays a huge part in the 'sway' issue.
Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2749 |
Posted: 04 Nov 2018 at 3:06pm |
Posted: 04 Nov 2018 at 3:38pm |
Hi Jato, I started another thread today on trailer and tongue weights vs. sway, can you let me know (preferably on that thread for continuity) what your trailer weights were when you encountered sway (if you know them), or if not, what you had on board (I can probably calc it pretty close from that)? I think you carry a full fresh water tank right? One battery or two? One propane or two? thanks!
Page <123 |
