  New Posts New Posts RSS Feed: RV 178 water dripping - exterior
Topic ClosedRV 178 water dripping - exterior
 Post Reply Post Reply Page  <1234 8>
CharlieM View Drop Down
Direct Link To This Post Topic: RV 178 water dripping - exterior
    Posted: 31 Oct 2018 at 10:20am
If you can get to the pump, replacing the check valve is an easy task. Order the part, remove three screws, replace three small plastic parts, replace three screws, check for leaks.
Direct Link To This Post Posted: 31 Oct 2018 at 3:29pm
Offgrid, I use my city water all the time. Always want to add a pressure regulator, amazing the difference in supplied pressure amongst sources. No issues with pump and fresh water tank, works fine, I don't travel with a full water tank in a 178.
Direct Link To This Post Posted: 31 Oct 2018 at 3:34pm
Just a caveat, the overflow for the fresh water tank is in the fill area. If the tank overflows it doesn't leak into the trailer. The OP has two issues, the fresh tank filling, which 99.9% sure is check valve and the water coming out of back of trailer with wet rear compartment floors, that is a leak.
Direct Link To This Post Posted: 31 Oct 2018 at 4:09pm
mcarter, understood. There is no functional difference in usage, its about convenience in not having to travel with water or fill the tank. I think I'll just stick with filling the tank and using the pump as needed. There's always water in my tank anyway.  If I'm going somewhere with water (rare for me) I can still travel with an empty tank and just fill when I get there. I know pressure varies a lot, this way I don't have to worry about it, or worry about leaky or frozen hoses.
Yes, BoulderGal has both a highly probable check valve failure and a leak, plus a third issue stemming from the leak, which are wet floors over a large area.  I'd like to be sure she gets that dried out before she has water damage problems on top of plumbing problems. The leak could I suppose be related to the overfull tank as well (overflow line leaking perhaps).
Direct Link To This Post Posted: 31 Oct 2018 at 4:18pm
Yepper, the 179s are a bit different than 178s, the 178 tank is on the aft end, had some issues with a full tank and towing. 179s are better. BTW the overfill and fill are external to the floor, connected directly to tank.
Direct Link To This Post Posted: 31 Oct 2018 at 4:32pm
179's are better if you're worried about what in aviation is called aft cg (sway risk increases). 178's are better if you have forward cg problems (tongue weight too high).  Either way hauling water can be an issue. Not something I want to do, it's just that the places I like to camp don't have water.
Direct Link To This Post Posted: 31 Oct 2018 at 4:47pm
+1
Direct Link To This Post Posted: 31 Oct 2018 at 9:02pm
Have to agree offgrid.  We normally camp where no water is available so we nearly always leave with a full tank of water.  National parks and state forest campgrounds may have water available but we are really fond of our well water.
BoulderGal View Drop Down
Direct Link To This Post Posted: 31 Oct 2018 at 10:03pm
Hi Mike, I'll have to climb under the trailer in the rain tomorrow afternoon to try this.  I tried to remove the cap on the fresh water tank before writing this and just couldn't get it undone.  I'll find some cardboard or something tomorrow to put on the ground as all we've have the past few days is rain.  I did check the cabinet and under the bed tonight and no signs of water at this point.  I'll let you know as your suggestion sounds good.  Several folks made suggestions about getting a pressure regulator but I already have a good one.
Thanks!!!!
Susan
BoulderGal
Direct Link To This Post Posted: 31 Oct 2018 at 10:06pm
Hi Charlie,
If I can get it to stop raining for even one day (this IS the Pacific NW) I will look into locating the pump.  Unfortunately, the Forest River manual is short on details as it appears it's the same one for every model.  Sure wish I could get my hands on a schematic.  Just call me "Jane of all Trades" and wishing someone was here to help!
Susan
BoulderGal
