  New Posts New Posts RSS Feed: Tv/radio amplifier
Topic ClosedTv/radio amplifier
Pod People View Drop Down
Direct Link To This Post Topic: Tv/radio amplifier
    Posted: 06 Oct 2018 at 8:02pm
the small button that activates the tv/radio amplifier will not stay engaged when I push it in. It immediately pops out and the amplifier is not engaged. It does amplify and work as long as I hold the button in. I have temporarily made a foam wedge that will hold it depressed.
I have seen that the entire plate is replacable for $25.
Has anyone else had this problem or replaced or repaired the entire plate( tv cable male connection, cable male connection and amplifier button)?
Thanks
Vann
Vann & Laura 2015 RPod 179
Direct Link To This Post Posted: 06 Oct 2018 at 8:08pm
I've not looked to see what's behind the plate, but I would not be adverse to popping the plate off to see what might be involved in replacing the switch. If it is soldered onto a circuit board you will likely have to find an almost-exact match. Otherwise you might be able to put in a replacement switch.
Direct Link To This Post Posted: 06 Oct 2018 at 9:30pm
I replaced mine for very same failure. Took about 20 minutes and as I recall I had to hardwire the 12V. I didn't try to repair the switch.
