  New Posts New Posts RSS Feed: Battery current draw
Topic ClosedBattery current draw
Ghosthawk View Drop Down
Direct Link To This Post Topic: Battery current draw
    Posted: 12 Sep 2018 at 8:35am
I don't know if this apply's to other models. But I discovered that on my 189 if I pull the lowest green 30a fuze I have no 12v to anything. Makes a quick easy way to pull power when your going to want it back on shortly.
I have used it a few times when wiring new 12v/USB plugin's in our pod.
Direct Link To This Post Posted: 12 Sep 2018 at 6:55am
All, the best way to do your energy budget for off grid solar is in amphours. It is misleading to do it in watt hours because a 100 watt solar module for example does not produce 100 watts for a 100 watt load in one hour of sunshine. its much less.
So start by estimating how many amphours a day you need. You need to know the current draw on each item and the daily hours of operation for each. Multiply then add. It sounds hard but its actually pretty easy.  Here is an example showing my summertime use. Lots of amhours for fans because its hot in NC in the summer. In the cooler months fans will be off but heater will be on so it works out to be a bit less but similar. Lights are really a minimal part of the load. I have a 12V TV which is why I've included that. Easy mod if you want to watch TV in the pod off grid and save lots of energy.
item dc current qty hours/day amphours/day
single led lite 0.2 4.0 2 1.6
dual led lite 0.4 1.0 2 0.8
bath lite 0.3 1.0 0.2 0.06
outside lite 1.4 1.0 0.1 0.14
small fan 0.5 2.0 24.0 24
fantastic fan h 2.8 1.0 0.0 0
fantastic fan m 1.9 2.0 0 0
fantastic fan l 1.3 1.0 24 31.2
fridge 12V 10.7 1.0 0 0
water pump 5.0 1.0 0.2 1
TV  12V 1.5 1.0 4 6
Radio 0.4 1.0 24 9.6
heater on 2.0 1.0 0 0
water heater on  0.6 1.0 1 0.6
total 75.0
Next, battery capacity. You can see that I have a total of about 75 amphours per day. As we don't want to bring our batteries below about 50%, I need a minimum of 150 amphours to get through one day without charging. If you want to go 100% solar and never charge from your vehicle or a generator, you will need about 2-4 days storage in summer depending on where you live. While you never get a day with zero solar output, this 2-4 days gets you through longer periods of cloudy or stormy weather. I have 220Ah battery storage (dual 6V GC2's) for 110AH useable and so expect to need to use my genny fairly frequently in cloudy weather.
On to solar sizing. A 100 watt module will not be the right answer for everyone. Your mileage will vary. The variation depends on several factors. Besides your actual loads as above, it depends on the time of year, the region you live in, whether you camp under trees or not, and whether you are manually moving around a portable solar module and keeping it pointing at the sun all day or (if you're lazy like me) have them permanently mounted to the trailer roof.
You can figure that a 100 watt solar module will deliver about 6-7Ah for your loads from an hour of full direct (perpendicular) sunshine.  This is not 100 watts/12 volts=8.3A because of the way solar modules are rated and the charge/discharge losses in the battery.  So if you have a perfectly clear cloudless day, no tree or other shading and keep your module tilted toward the sun, moving it from east to west over the course of the day, you might get 50 amp hours from it. Where I live in the mid atlantic with solar flat on the roof I get about 30 amphours on a good summer day from 100 watts. If I'm not under trees (which I often am). So, I plan on installing a 350 watt module on the roof of my rPod, which should give my about 100 amphours a day in summer when not under the tree canopy. You can get a 350 watt module for under $200 now so why not?  I'll revert to the genny or TV charging when forest camping as needed.
To mitigate the genny noise and smell you can get a nice 2kw inverter-generator which runs very quietly, convert it to propane, and put it  and a 20lb tank far from your campsite on a 100 ft extension cord.  That's what I do, no stink of gasoline, and I can barely hear it. Running it once a day in late afternoon/early evening when everyone is making noise and cooking helps as well.  I don't fell bad about running mine, its a lot quieter compared to the family in the next campsite with the shrieking kids and barking dogs Angry
Direct Link To This Post Posted: 11 Sep 2018 at 6:59pm
I got the panel, cable and controller from Windy Nation in Ventura CA.  The controller is branded with their company name. I don't know who makes it.  It will handle more than one panel.
Yes, with that cold, you're going to need some power to run the furnace.  We've had temps in the 20's on some mornings with frost on the meadow grass, and it was no problem getting the pod up to a comfortable temperature pretty quickly.  Taking a leak in the night, on the other hand, is a little chilly, but with a warm bed and blankets, you recover quickly.
Colorado r-pod guy View Drop Down
Direct Link To This Post Posted: 11 Sep 2018 at 1:41pm
Thanks for the insights.  Which charge controller are you using?
I expect that we will be setting the thermostat at about 50 degrees (during the night only in weather averaging mid-40s during the day, low 20s at night.  Reading all the responses thus far, I'm leaning toward buying a PV charging system.
Direct Link To This Post Posted: 11 Sep 2018 at 1:10pm
Running the heater in the morning for about a half hour or so, using our LED lights for maybe 4 hours (a problem with the 172 is it doesn't have a lot of windows, thus not a lot of ambient light), and charging the cell phones and Macbook, it would be hard to get up to 400 watt-hours in a day.  For us, by the end of the solar charging day, our batteries are fully charged and the controller has cut down to a trickle charge.  Thus, for us we're living the life of Riley on the output of our 100 W solar panel.
It's a question of how much power you are consuming and how balance consumption with recharging.  If you use 1000 watt-hours a day, then you'll need a solar (or other charging) system that has that capacity.
Direct Link To This Post Posted: 11 Sep 2018 at 10:33am
50% discharge on a 12V 100AH battery is roughly 600 watt-hours. On a good summer day below the 40th parallel you should get 6-8 hours of sunshine (no clouds). I generally expect roughly 80% on our panels (we're at 37 degrees north), and we rarely have clouds in the summer. So, 80% at 7 hours gets you a bit over 560 watt hours with a 100 watt panel.
Figure out how many watt-hours you use in a day, and see if that is close. Even if it's not quite enough, it could take weeks to add up to a problem.
Direct Link To This Post Posted: 10 Sep 2018 at 10:22pm
If you take reasonable efforts to conserve power a 100W solar system can keep your batteries indefinitely charged.  Something like this would work fine:  https://www.amazon.com/ACOPOWER-UV11007GD-Foldable-Generator-Controller/dp/B01MU4PGLQ/ref=sr_1_5?ie=UTF8&qid=1536635733&sr=8-5&keywords=100w+solar+panel+suitcase&dpID=51A%252BtuB8EgL&preST=_SY300_QL70_&dpSrc=srch
As for generators, yes the noise is awful.  You can get duel fuel inverter generators that run just fine on propane.  The only problem is there are less electrons in the propane than gasoline so when  you convert the fuel to electricity you get less.  [For those who take that literally, I'm not serious.  I know that the electrons in propane and gas molecules don't get sent into the generator.  It's just that there is less energy in the combustion of propane that there is in gasoline.]
I never let our batteries get fully discharged as you suggest.  It's not good for their longevity.  When you camp with a solar system, set it up when you arrive and take it down when you leave and you should have electrons enough to lend to your neighbors.
Direct Link To This Post Posted: 10 Sep 2018 at 9:02pm
Many thanks for all the feedback.
I've already replaced all the incandescent bulbs with LEDs.  As an aside, my external power meter indicates that one two-bulb light fixture with incandescent bulbs uses 46 watts, while the same fixture with LEDs uses 3 watts. Quite a difference especially if you have several fixtures on simultaneously.
We never use the fridge as we use a five day cooler that does the job just fine.  The only thing I'm really concerned about is heat during cold weather, which, if we use the jumper cables from the truck method it seems like that should work just fine for a few days.  It does make me wonder about putting the extra load on the alternator while out in the boonies, though.
IMHO, generators stink.  Add the gasoline, noise, yet another thing to maintain, and more weight.  Maybe I should just go ahead and get the lobotomy now.  Nothing ruins the moment like somebody nearby running a generator so they can watch Gilligan's Island reruns or whatever while we're trying to get some sleep before climbing a 14er the following day.
Going solar sounds like a great idea, but there are so many options my head started hurting trying to figure out the most reliable and cost effective way to go about it.  Is a 100 watt panel really enough to charge a deep cycle battery in one day if the battery is at about 50% charge?  I saw an Airstream a while back and the top was completely covered by flexible solar panels.  Obviously they are doing more than just charging a battery...
Happy camping to all.
Direct Link To This Post Posted: 10 Sep 2018 at 12:24pm
Colorado guy, here's what we do to minimize battery use:
1.  We replaced all the interior lights with LED (I was going to replace the outside light that we almost never use anyway, but inadvertently got the wrong bulb - hardly worth the effort).
2.  We run the refer on gas when not connected to AC, which is almost all the time b/c we dry camp.
3.  We keep the batteries fully charged with our 100A solar panel.
4  We minimize the use of the heater weather permitting.
4.  We don't use much of any other appliances or electronics, except keeping the cell phones & macbook charged.
5.  We try to pay attention to energy use and turn stuff off when not needed.
With these simple things, we really have no issues with running low on DC power.
If you want to use things like the AC, micro's, and other high AC powered appliances, your only realistic option is to either go to a camping place that offers AC power or use a generator to run them.
Others have commented on the high power consumption of the furnace fan and we've had the same experience.  That's why we try to run it only for a little bit in the morning - good blankets are cheap and cozy - and we can recover the loss of those electrons by recapturing some from the good old sun with our solar panel.
The biggest problem for us when dry camping is the fresh water and gray water tank capacity.  It's easy to use more than you should and run out of water or space for gray water.  Again, being conscious of it makes you use less.
A good quality deep cycle battery or, better yet - in the view of many - a pair of 6v golf cart batteries will give you all the electricity you need if you combine it with a solar panel and try to conserve energy.
Direct Link To This Post Posted: 10 Sep 2018 at 11:35am
The battery disconnect serves as a convenient way to isolate battery for maintenance or long term storage. I don't use it for anything other than that, but to me it is handy.
