Page <1 6789> |
Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2735 |
Topic: Running refrigerator on propane while drivingPosted: 31 Aug 2018 at 8:13pm |
Similar but different. The first one attributes thought to the hammer, the second attributes thought to the user.
Joined: 03 Apr 2011 Location: Mayville, WI Online Status: Offline Posts: 1447 |
Posted: 31 Aug 2018 at 6:51pm |
couple of points. I will crawl under our pod tomorrow and look but I recall the gas service entering the front of the pod like the electrical feed. And regulators cut off the gas feed if the line is broken. They even shout the supply off if the valve is opened to quickly. As for gas stations gas fumes are heavier than air and pumps are outside. Slim chance they will get into the flame on the fridge. I run ours when we drive on propane.
Posted: 31 Aug 2018 at 3:40pm |
That is an interesting statistic, which can say whatever you want, that's what nice about statistics. I have never had a 12V fire issue on a fused line, which means or associated with the battery or an unfused line. Again the issue isn't about a propane device, it's about an open propane line and a fire, the fire start is not the object, the fire will find an open propane source. Which is different than a tank exposed to heat that explodes. Not here to preach or teach, but NOT traveling with an open propane source regardless of fire source.
Respect Furpod, but not convinced here, my friend. Happy Trails. |
Posted: 31 Aug 2018 at 11:11am |
according to the RVIA statistics.. the number 1 cause of RV fires is 12v issues. Not propane in any way or at any time. ! guy, with a video, where he admits he is biased, does not a "fact" make...
what's that old saying.. "to a hammer, everything is a nail".. |
Posted: 31 Aug 2018 at 10:29am |
+1 to mcarter. Some of this relates to people's past experience with fire of any kind. What is the saying? "Once burned, twice shy." My SO had an early life experience of being burned out of her home when she was a a toddler. It kind of changes your perspective. Or as Dirty Harry once said "Are you feeling lucky?" To those of you that travel with your propane on, good luck. It only takes once, and in fact, if you're only traveling for 6 hours or so, you probably don't need to run your refer at all for the want for a few degrees. For those of you that can run on battery, it is probably the safer way to go. This is another discussion of the subject with a little lighter approach: https://www.youtube.com/watch?v=o91vm9M9Ll0
Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3384 |
Posted: 30 Aug 2018 at 7:18pm |
+1 to Keith and Dar and +1 to furpod. Yes this was just discussed a few days ago at length. We have always used propane while driving and normally when camping. Will use electricity if we camp at a site where it is available and that isn't too often. So mark us in the 50% group that uses propane and believe that is the way to go.
Posted: 30 Aug 2018 at 6:27pm |
I know the dilemma associated with this issue. I have done some research and I am probably the one referred to as "one poster" who offered a negative to propane use while traveling. For your own purposes, Google "RV traveling with propane on". make your own conclusion and here is a short video offered by a full time RVer and a safety guy:
https://www.youtube.com/watch?v=wMtzsY3Ps8c The issue is NOT the reefer, it is an open propane line while traveling and the opportunity for an accident or obstruction to hit the bottom of the pod. Where are your propane lines? They are under the pod floor on the road surface side. How much of a spark does your igniter make when lighting a propane fueled device. You don't have to damage a tank, just a line. What most RVer authorities say is "what is your acceptable level of risk and safety". That's the bottom line. Thanks |
Posted: 30 Aug 2018 at 2:21pm |
Once again :) I always run my fridge on battery when traveling. I have used propane.
BVK
Joined: 21 Jul 2018 Location: Pacific NW Online Status: Offline Posts: 21 |
Posted: 30 Aug 2018 at 2:06pm |
I failed to notice the "while driving" part of the question. We actually haven't run the fridge at all while driving, not that I'm necessarily opposed to it. I think we just don't plan to use the refrigerator at all, frankly. It's nice to have, but we're never taking into account that we have a fridge when shopping. If we can't keep it in a cooler while we're travelling, we don't carry it. If I found a great deal on some free steaks that I had to keep frozen, sure, I'll run the fridge on gas while driving for that!
2012 RP-171 HRE, 2006 F-150
Richand Cindy
Joined: 16 Apr 2016 Location: New Jersey Online Status: Offline Posts: 328 |
Posted: 30 Aug 2018 at 2:04pm |
Some bridges and tunnels do not allow propane tanks at all so you have to avoid them. Others allow them but they must be turned off and some gas stations require you to turn off propane tanks. We always run on propane and have never had to turn it off when fueling and have not had a problem. Basically having a three way refrigerator is a waste. Either we use propane or campground electricity. Never used the battery option.
NEW: 2018 Passport Elite 23RB + 2017 Ram 1500 Diesel |
Page <1 6789> |
