Page <12 |
crankster78
Joined: 08 May 2018 Location: Minn Online Status: Offline Posts: 163 |
Topic: Lug Nut WrenchPosted: 23 Aug 2018 at 5:31pm |
Greetings The lugs are 3/4 inch. buy a deep inpact socket and a long 1/2 inch drive handle. A small floor jack is what I pack along. A torque wrench is a good idea to have {1/2 inch drive) 90 to 100 pounds of torque. Check the torque after a couple of 100 miles
Crankster 78 R-179 2015
Dave & Donna
Joined: 18 Apr 2017 Location: Nebraska Online Status: Offline Posts: 55 |
Posted: 23 Aug 2018 at 9:00pm |
Thank you marwayne!!
D&D plus Rusty
2017.5 R-pod 179 |
wooleeman
Joined: 01 Sep 2017 Location: Southeastern PA Online Status: Offline Posts: 80 |
Posted: 24 Aug 2018 at 5:02am |
I’m not sure if using the torque wrench to remove lugs would damage it but if you use it, set the torque well above the specified torque (100) lbs. I can’t see how it could hurt it if you set it at lets say 150. |
2022 RP-202
2016 RP-179 (Sold 9/2020) 2014 Silverado Crew Cab. 6-1/2' Bed Golden Retriever (DOB 6/16/2020) English Bulldog (RIP 6/15/2020) |
Posted: 24 Aug 2018 at 8:45am |
My understanding is that if you are using a torque wrench to remove tight lug nuts, you run the risk of damaging the cogs inside and getting it out of calibration. A breaker bar is much better for this purpose since it does not need to be calibrated. Tightening a torque wrench to above the stated torque would not necessarily prevent getting it out of calibration.
wooleeman
Posted: 24 Aug 2018 at 9:06am |
You may be correct but they are designed to torque in both directions. So setting it higher shouldn’t hurt it if you don’t reach the set torque.
2022 RP-202
Posted: 24 Aug 2018 at 3:47pm |
+1 to SH. Spot on.
Ben Herman
Joined: 26 Apr 2018 Location: Gr Junction, CO Online Status: Offline Posts: 359 |
Posted: 24 Aug 2018 at 4:56pm |
I stopped at Harbor Freight today and picked up a folding 4 way lug wrench; easy to pack and good to have in case. Not the quality of tool that I'd use all day/every day in a shop but perfectly adequate to live in my Pod toolkit and (hopefully) never get used. $10.99.
Posted: 24 Aug 2018 at 5:09pm |
Let me know how that works on a 100 lb torque. You must be young:)
DavMar
Joined: 04 Aug 2017 Location: Lexington, NC Online Status: Offline Posts: 592 |
Posted: 04 Sep 2018 at 4:46pm |
Harbor Freight is your friend here. If you ever had to break the torque off a 100 pd lug nut you'll be glad your bought a cheap four way lug wrench from them. Or better go buy a cheap breaker bar and torque wrench from them and while your at it get a cheap 3 ton bottle jack. Then go shop around at your local FLAP (friendly neighborhood auto parts) store for a cheap short extension and appropriate deep well socket, unless you can somehow find these cheaper at HF. You now have the perfect tire changing kit!
Page <12 |
