  New Posts New Posts RSS Feed: passing vehicles with the trailer
Topic Closedpassing vehicles with the trailer
crw8sr View Drop Down
Direct Link To This Post Topic: passing vehicles with the trailer
    Posted: 18 Aug 2018 at 5:57pm
I had the idea after our first outing with our R-pod and not being able to see what's back there.  I found a Peak wireless backup camera in the clearance bin at Menard's for $60 and took a chance it would work.  I attached it to the license with some metal strap.  Removed the license plate frame from the R-pod and spliced the power to the camera into the license plate light and reattached it to the R-pod.  The lights on TV have to be on to power the camera which is okay because I drive with my lights on on the highway anyway.  The monitor is plugged into a power port (formerly called cigarette lighter) and stuck on the windshield.  Viola!  I can see what you're doing back there, so behave yourselves!!!
Chuck & Lyn
Izzy, Morkie. RIP
Zoe Joy & Gracie, Yorkie
2018 R Pod 190
2019 Traverse
Direct Link To This Post Posted: 18 Aug 2018 at 9:28pm
I don't know the type of tow vehicle the OP has. I purchased a set of towing mirrors from 1A Auto for our Nissan Frontier. These are power, heated mirrors which are larger than the stock mirrors. They are extend (manually) to give a better view of what is behind. Many states only specify that you should be able to behind you for 200 ft. Some specify that it has to be a line of sight parallel to the tow vehicle. If the trailer is wider than the tow vehicle, towing mirrors, either replacements or strap/clamp on mirrors are essential.
geewizard View Drop Down
Direct Link To This Post Posted: 19 Aug 2018 at 9:53am
What I generally do is use my towing mirrors (you do have them, don't you?) and my depth perception to see when the end of my TV+trailer is 1 or more lengths in front of the passed vehicle.  Then I signal and check the mirrors again.  THEN, I move over into the other lane.
The other visual clue is the 16-30 year old driver who tailgates you as you pass then zips into the gap between you and the passed vehicle and gives you the finger as they pass you on the right side.  Star
Sometimes shadows of the passed/passing vehicles can help.
Used to be that semi drivers would flash their headlights at you when it was safe to pull back into their lane.  This generation of truck drivers evidently don't know about that courtesy.
2004 Outfitter Apex 8 camper
2014 Toyota Tundra DC
Direct Link To This Post Posted: 19 Aug 2018 at 10:04am
Yeah! I've noticed that too. They used to flash their tail lights when we offered them the same courtesy.
Direct Link To This Post Posted: 19 Aug 2018 at 2:34pm
Some of them still do. I think it is about 50/50.
Direct Link To This Post Posted: 19 Aug 2018 at 3:04pm
Turn the blinker on like your asking a question, they will tell you when your clear, that's how they do each other. They don't want an accident anymore than you do.
